Help with dialog boxes and layer list
tkraftV8RQQ
tkraftV8RQQ
I have an autolisp command i created that compares overlaps of areas you select by layer.
I'm trying to make a dialog menu (dcl file) but I can't get the layer list (just a simple autolisp list) to show in a dcl Tile of any kind. I'd like it to update whenever the list is updated by prompting the user. There's 4 groups for layer lists and then a "run" option after they're all set.
CodeDing
@tkraftV8RQQ ,
Maybe this example will help you:
Lisp File:
(defun C:TEST ( / dcl_id)
  (setq dcl_id (load_dialog "c:\\myFolder\\mySubFolder\\myfile.dcl")) ; Load the DCL file.
  (if (not (new_dialog "mydialog" dcl_id)) ; Initialize the dialog.
    (exit)                                 ; Exit if this does not work.
  ;define our items
  (setq *myItems* '("Item 1" "Item 2" "Item 3"))
  ;add items to our List box
  (start_list "lstbx_1")
  (mapcar 'add_list *myItems*)
  (end_list)
  ;add items to our Popup box
  (start_list "popbx_1")
  (end_list)
  ;define an action for our button (create a new list in our case)
  (action_tile "btn_1" "(progn
    (alert \"This button will now update the lists.\")
    (setq *myItems* (cons \"Item 9\" (cdr *myItems*)))
    (start_list \"lstbx_1\")
    (end_list)
    (start_list \"popbx_1\")
    (end_list)
    (alert \"The Lists have now been updated.\")
  ;start dialog
  (start_dialog)         ;Display the dialog box.
  (unload_dialog dcl_id) ;Unload the DCL file.
  (princ)
);defun
DCL File:
mydialog : dialog
  label = "My Sample Dialog";
  : list_box {
    key = "lstbx_1";
    label = "My List Box:";
  : popup_list {
    key = "popbx_1";
    label = "My Popup Box:";
  : button {
    key = "btn_1";
    label = "Update Lists";
  ok_only;
Best,
~DD
diagodose2009
Here is you see . Must see the file .gif attached.
CodeDing
^^^ CAUTION ^^^
A randomly named .ZIP file, with a short comment expressing you should open said zip file?!
I would recommend to NOT download that file!
Sea-Haven
I use a library list box allows you to change parameters like Title width multi or single etc.
The 1 I use is by Alan J Thomson, Lee-mac.com has two also a single list pick or a nice make a new list where you add items so can see them.
