help with boxed_radio_column with multiple rows?
DC-MWA
Message 1 of 30
DC-MWA
Hi all,
I'm trying to make a help file for one of the larger programs we use.
I've got the basics figured out.
I'm using radio buttons to call up text describing each function.
At this point I can only make one row of radio buttons. If I break them up into two, I lose the functionality of the buttons.
I'm looking to have a radio_column with two or more rows within.
I have attached the lisp and dcl files.
I'm hoping this is semi-simple although after searching, I'm not sure.
Thanks.
-dc
Replies (29)
Message 2 of 30
Sea-Haven
Not sure if this will help but this is my radio button pick method it returns button number. RB1-RBx etc. So second radio button column would be say RB6+
(setq x 1)
(repeat (- (length butlst) 1)
(setq k (strcat "Rb" (rtos x 2 0)))
(action_tile k  (strcat "(setq but "  (rtos x 2 0) ")" "(done_dialog)"))
(if (= ahdef x)(set_tile k "1")) ; sets button default to 1st button
(setq x (+ x 1))
Message 3 of 30
DC-MWA
Not sure how to apply this to my situation. I will play with it and see where it takes me.
Thank you very much for your reply.
-dc
Message 4 of 30
Sea-Haven
The repeat would be total number of buttons the key is RBX and it returns the button number not a value. so you would have a cond checking button number. I have not tested just an idea.
Message 5 of 30
DC-MWA
I could not wrap my simple mind around your code.
So I went dawn another path. I got the multiple rows to work in the radio_column, but now I do not know how to get "Mylist" to display in the list_box. The radio buttons work but...
I'm hoping I'm close and this an easy fix.
See attached lsp and dcl files.
Message 6 of 30
Sea-Haven
Have a look at Lee-mac.com "Listbox" example.
So you want to click a radio button then have a help message, why not just use (alert msg1) etc just have the options buttons only.
You can have a edit box called Text but you will have to close and reopen the dcl. So you might start with Option 1 and then as you pick redo the text.
Message 7 of 30
DC-MWA
Thank you.
The lisp I sent first "test.lsp" it uses radio buttons to display text based on selection but has only one row in radio_column.
The second lisp "doit.lsp" has multiple rows in radio_column, does not display text in list_box.
In test.lsp it works wihout closing and reopening the dcl.
I'll keep trying. Thank you for your time my friend.
Message 8 of 30
john.uhden
You could switch your approach to an array of toggles, such that when you pick one it toggles the others off.
I don't think Autodesk provides a radio_array option.
John F. Uhden
Message 9 of 30
DC-MWA
I got the multiple rows to work.
Now I'm having trouble it to show mylist at selection at it did my first attempt.
Message 10 of 30
DC-MWA
Message 11 of 30
@DC-MWA  Does this solve your problem ??
If yes I will make adaptations and I will set the example for you !!
Message 12 of 30
DC-MWA
That's what I need except I need multiple rows of radio buttons otherwise the dialog gets huge.
Message 13 of 30
@DC-MWA  Sorry for not having time to make the changes !!
One question: Why not use popup_list instead of this huge list of radio_buttons ??
Message 14 of 30
DC-MWA
Pop-up list would work. The program I'm working on needs to put the separate items in the face of my users.
When it opens pow! options in your face.  lol
Message 15 of 30
Sea-Haven
Copy this to command Line
(alert (strcat "this is a pop up\n\nIts in your face \n\nand very simple to create"))
Message 16 of 30
DC-MWA
Alert box? How does this help?
Message 17 of 30
I came back lol.
I attached the example of how you can deal with these sutuations, make the modifications on your own.
Observations:
  • As I said, I replaced radio_button with popup_list.
  • I'm just a novice in this AutoLISP world and I probably have a smarter way of writing this.
I hope it helps.
If it solved your problem, mark it as a solution.
;c:BRCWM
;;by - Júnior Nogueira
(defun c:BRCWM ( / dcltest listX list1 list2 list3 dx dy )
;;add *error* handling on your own
 (JR:writedcl)
 (setq dcltest (load_dialog dcl))
 (if (> dcltest 0)
  (if (new_dialog "dclt" dcltest)
   (progn
    (setq erro* "Function cancelled,quit / exit abort,console break/ list nil")
    (setq list1 '("ItemX" "ItemX" "ItemX" "ItemX" "ItemX"))
    (setq list2 '("ItemY" "ItemY" "ItemY" "ItemY" "ItemY"))
    (setq list3 '("ItemZ" "ItemZ" "ItemZ" "ItemZ" "ItemZ"))
    ;(setq dx (dimx_tile "img"))
    ;(setq dy (dimy_tile "img"))
    ;;go first here!
    (defun JR:radiobuttons ( radiobuttons )
     (cond
      ((= radiobuttons "radiobuttons1")   (setq listX  list1  topico  "radiobuttons1"))
      ((= radiobuttons "radiobuttons2")   (setq listX  list2  topico  "radiobuttons2"))
      ((= radiobuttons "radiobuttons3")   (setq listX  list3  topico  "radiobuttons3"))
     (start_list "item" 3)
     (mapcar 'add_list listX)
     (end_list)
     ;(start_image "img") ; previous code!
     ;(fill_image 0 0 dx dy 0)(end_image) ; previous code!
     (set_tile "msg" "Select an item from the list, please")
    );defin end!!
    (foreach x '("radiobuttons1" "radiobuttons2" "radiobuttons3")
     (action_tile x "(JR:radiobuttons $key)")
    (action_tile "item" "(setq item (nth (atoi $value) listX))") ; previous code!
    (action_tile "help" "(c:JR:Help)")
    (action_tile "cancel" "(done_dialog 0)" )
    (action_tile "accept" "(if item (done_dialog 1)(alert erro*))")
    (setq reason (start_dialog))
    (unload_dialog dcltest)
    (cond
     ((= reason 0) (princ "\nCanceled."))
     ((= reason 1)(JR:Actiontopicitem topico item))
   );;progn end!!
  );;If end!!
  (alert "Oops, the dcl file could not be loaded!")
 (if (and dcl (setq dcl (findfile dcl)))
  (vl-file-delete dcl)
  (princ)
;JR:actiontopicitem
;;Dcl Actions
;;Arguments [topic] and [Item]
(defun JR:Actiontopicitem ( %topico %item / postesbloco )
 (alert (strcat "Do something in " %topico " and " %item))
;;JR:writedcl - Junior Nogueira
;;write your help
;;No arguments
(defun c:JR:Help nil
 (alert "Your help!")
;;Write the dcl in my temp folder!
;;No arguments
(defun JR:writedcl ( )
 (if
  (and (setq dcl (vl-filename-mktemp "tmp.dcl"))(setq arquivo (open dcl "w")))
   (mapcar '(lambda (x) (write-line x arquivo))
    (list
     "dclt : dialog"
     "label=\"Teste - Autor: Júnior Nogueira , V 1.0\";"
     "initial_focus=\"msg\";"
     ": spacer"
     "  height=1;"
     "  : text"
     "   label=\"Select the topic and then the item\";"
     "   key=\"msg\";"
     "     alignment=centered;"
     "     height=2;"
     "  : row"
     "   fixed_width=true;"
     "   spacer;"
     "     : column"
     "       alignment=top;"
     "       fixed_height=true;"
     "       : text"
     "       label=\"Select topic\";"
     "     : radio_column"
     "        alignment=top;"
     "       : radio_button"
     "        label=\"radiobuttons1\";key=\"radiobuttons1\";"
     "       : radio_button"
     "        label=\"radiobuttons2\";key=\"radiobuttons2\";"
     "       : radio_button"
     "        label=\"radiobuttons3\";key=\"radiobuttons3\";"
     "    spacer;"
     "  : column"
     "     alignment=top;"
     "     children_fixed_width=true;"
     "     children_fixed_height=true;"
     "        : text"
     "          label=\"Select item\";"
     "        : list_box"
     "           key=\"item\";"
     "           width=40;"
     "           height=16;"
     "           alignment=top;"
     "    spacer;"
     "    spacer;"
     "    spacer;"
     "  : column"
     "   :concatenation"
     "       : button"
     "         label=\"help\";key=\"help\";"
     "         width=15;"
     "         height=2;"
     "       : button"
     "         label=\"cancel\";key=\"cancel\";"
     "         is_cancel=true;"
     "         width=15;"
     "         height=2;"
     "       : button"
     "         label=\"accept\";key=\"accept\";"
     "         width=15;"
     "         height=2;"
 (if arquivo
  (close arquivo)
Message 18 of 30
DC-MWA
First: let me say that this awesome, no separate dcl file... love it!
Second: I truly appreciate your time and effort on this.
As the name of the post states, I'm trying to get multiple rows of radio buttons. In the DOIT.lsp I attached, I got the multiple rows of radio buttons to work properly, I just can't get the description to show in the list_box.
In your code, the description works well, but I need multiple rows of radio buttons.Capture.JPG
Again, I truly appreciate your time and effort on this.
Thank you
-dc
Message 19 of 30
Sea-Haven
My Autocad R12 customization manual refers to dcl "text_part" as a tile, it can be one line or multiple lines. This may be one way around the problem, my manual is a paper copy but there should be a online copy at Autodesk under "developers help, regarding DCL's"
You could look at calling a sub dcl it will display over top till say you press OK
I found some sample code. Just use find its about 1/2 way down.
Message 20 of 30
DC-MWA
Thank you.
