Help with addselected in autolisp
DC-MWA
Message 1 of 9
DC-MWA
Working on a "draft by pick" routine.
It almost works.
I can't get it to use the current aec style for soors, walls, windows like the native walladdselected, windowaddselected, dooraddselected commands do.
Also, it will not match dimensions scale as the native addselected command does.
I think I'm using entsel and ssget wrong.
It would also be nice if after running the routine of all style, layer, linetype settings returned back to before using.
I have attached the lisp file.
Replies (8)
Message 2 of 9
devitg
Learn about SSADD .
Message 3 of 9
DC-MWA
Adding to selection? I only want one selection and to issue command by name of item picked.
Message 4 of 9
devitg
(setq entspecial (ssget "L"))
( (or (= CMD "POLYLINE") (= CMD "LWPOLYLINE")) (command "addselected" entspecial) )
I have no civil
you can try
Adds an object (entity) to a selection set, or creates a new selection set
Supported Platforms: Windows and Mac OS
Signature
(ssadd [ename [ss]])
ename
Type: Ename (entity name)
An entity name.
ss
Type: Pickset (selection set)
A selection set.
Return Values
Type: Pickset (selection set) or nil
The modified selection set passed as the second argument, if successful; otherwise nil.
Message 5 of 9
DC-MWA
You lost me.
My programming is limited as you can see.
Message 6 of 9
DC-MWA
It issues the command, but it does not act like the native addselected, walladdselected, dooraddseletec, windowaddselected cmmands.
It issues command but used the current wall, door, window, dimension settings rather than using the data from the slected item as the native commands do.
If I do the same thing on the command line it works great.
So the it seems that the selection is feeding the addselected functions wrong.
Message 7 of 9
Kent1Cooper
The (command) function works only with native AutoCAD command names.  Plain old ADDSELECTED is one of those, but not  the ones with prefixes such as WALL.  Custom-defined commands such as those are called using the name with the C: prefix under which it was (defun)'d, and in parentheses:
(C:WALLADDSELECTED)
but you're not supposed to be able to use arguments, such as your entity, in such a calling of a custom command.
I don't have the Architectural package, so I can't try it, but if you Search this Forum, there are threads about getting custom-defined commands to work, even including maybe some arguments.  Shot in the dark -- you could try making the object a pre-selection and call the C:Command, e.g.:
       (= CMD "AEC_WALL")
       (sssetfirst nil (ssadd entspecial)); pre-select/highlight/grip it
       (C:WALLADDSELECTED); call the command
Kent Cooper, AIA
Message 8 of 9
dbhunia
Hi
I gone through your code......
What I get there if you replace the line.....
(setq entspecial (ssget "L"));;;;;;;it gives a selection set
with (setq entspecial (cdr (assoc -1 ENT)));;;;;;it gives a entity name
Because "ADDSELECTED" wants Either "Select object" (by direct user input) Or "Entity Name" (In code).
your code may work, because I do not know which AutoCAD you are using..........
I tested in AutoCAD 2017, here only "ADDSELECTED" is available ........
And if the other commands are not native AutoCAD command, then approach with the process as @Kent1Cooper said......
Check the sample code for "TEXT" only........
(defun C:1 (/ entspecial)
(setvar "cmdecho" 0)
(setq ENT (entget (car(entsel "\nSelect object: "))))
(setq CMD (cdr (assoc 0 ENT)))
(setq entspecial (cdr (assoc -1 ENT)));Get Entity name
(cond
(= CMD "TEXT")
(Command "ADDSELECTED" entspecial
(getpoint "\nSelect Insertion Point: ")
(getstring "\nType desired text: ")
(setvar "cmdecho" 1)
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 9 of 9
DC-MWA
Thank you.
