Help with a INITGET
Help with a INITGET
msarqui
Help with a INITGET
msarqui
Hi guys,
Could someone help me please?
I trying to make a INITGET to return to the previous page, but it is not working...
(defun InitYesNo ( / return yesno)
(setq return (getvar "ctab"))
;;;...my routine will change the layout page here...
(initget "Yes No")
(setq yesno (cond ((getkword (strcat "\n  **  Would you like to return to <"return"> page? [Yes/No] <Yes>: **")) ( "Yes" ))))
(cond
	((eq yesno "Yes")
		(setvar "ctab" return)
	((eq yesno "No")
		(exit)
);cond
Thanks.
Marcelo
paullimapa
Try this:
(initget "Yes No")
(setq yesno (getkword (strcat "\n  **  Would you like to return to <"return"> page? [Yes/No] <Yes>: **")))
(if(not yesno)(setq yesno"Yes"))
(cond
    ((eq yesno "Yes")
    ((eq yesno "No")
        (exit)
);cond
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
ВeekeeCZ
@msarqui wrote:
Hi guys,
You have wrong parentheses inside of cond... Your (getkwork) is the test and if this is nil (means hit ENTER) then it goes for another test (there is none in your code) and your "Yes" result is missed. So the solutions is to have "Yes" as another test function.
  (initget "Yes No")
  (setq yesno (cond ((getkword (strcat "\n  **  Would you like to return to <"return"> page? [Yes/No] <Yes>: **")))
		    ("Yes")));)
  (cond
    ((eq yesno "Yes")
    ((eq yesno "No")
     (exit)
    );cond
But you can simplify it a lot using test for "No"
(defun InitYesNo ( / return)
  (initget "Yes No")
  (if (= "No" (getkword (strcat "\n  **  Would you like to return to <"return"> page? [Yes/No] <Yes>: ")))
    (exit)
  ) ;if
msarqui
Thanks guys
And thanks BeekeeCZ for the explanation. It was realy helpful. Smiley Wink
