help to plot cordinate
pullstackautocad
Message 1 of 9
pullstackautocad
i want my excel data to be drawan this way help
Replies (8)
Message 2 of 9
pullstackautocad
this are all distance
Message 3 of 9
pullstackautocad
this are all distance in mm.
Message 4 of 9
pullstackautocad
or simply this way
Message 5 of 9
pbejse
Post your excel file, I would assume the data would be in CSV format? if not we would suggest doing so, far more easier and simpler to code
Message 6 of 9
Sea-Haven
Pretty straight forward pick top Pline, then other line, get the Y difference between the Vertice and the line and apply a scale factor if required, typical road long section has a vertical scale.
This is a start.
;Calculates level of a point in cross or long sections
; BY alanh 2014
(setvar "cmdecho" 0)
(princ "\n To run just type SRL")
;;-------------------=={ Parse Numbers }==--------------------;;`
;;  Parses a list of numerical values from a supplied string. ;;
;;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;
;;  Arguments:                                                ;;
;;  s - String to process                                     ;;
;;  Returns:  List of numerical values found in string.       ;;
(defun LM:ParseNumbers ( s )
    (lambda ( l )
      (read
        (strcat "("
          (vl-list->string
            (mapcar
              (function
                (lambda ( a b c )
                  (if
                    (or
                      (< 47 b 58)
                      (and (= 45 b) (< 47 c 58) (not (< 47 a 58)))
                      (and (= 46 b) (< 47 a 58) (< 47 c 58))
                    b 32
              (cons nil l) l (append (cdr l) (list nil))
    (vl-string->list s)
(defun c:SRL ()
(setq olddimzin (getvar "dimzin"))
(setvar "dimzin" 0)
(if (= dwgscale nil)
(setq dwgscale (/ 1000.0 (getreal "\n enter vertical scale ")))
;(setq datum (getreal "\n Enter datum level "))
(setq datum (car (LM:ParseNumbers (cdr (assoc 1 (entget (car (entsel "\nPick datum text"))))))))
(setq test 1)
(setq pt1 (cadr (getpoint "\npick datum")))
(while (= test 1)
(setq pt2 (cadr (getpoint "\npick point")))
(setq dist (/(abs (- pt1 pt2)) dwgscale))
      (setq en1 (car (entsel "\nSelect text number:" )))
      (if (/= en1 nil)
        (progn
        (setq tent (entget en1))
        (setq a (+ dist datum))
        (setq a (rtos a 2 3))
        (setq el (subst (cons 1 a) (assoc 1 tent) tent))
        (entmod el)
	  );progn
       (princ "\nplease pick again"); else
     );if
); while t
(setq el nil
 en nil
a nil
en1 nil
test nil)
(setvar "cmdecho" 1)
(setvar "dimzin" olddimzin)
(princ)
)	;ends main defun
You can write direct to excel, but need a dwg and an Excel, will there be say multiple long sections ?
Message 7 of 9
pullstackautocad
this is an excel i donot have dwg... i work in a company were we make to make driveway sections..
Sorry but couln't understand how this lisp runs.. its ask me datum text
Message 8 of 9
pullstackautocad
help me with simple
Message 9 of 9
Sea-Haven
Ok 1st up for driveways I have a vehicle check to make sure they dont bottom out, just ask for more info.
The code is based around a cross or longsection, picking points. The dwg would have a Rl for the datum line in your case do not need one as you would just use the Y value of the picked line so can work out the difference in the Y values it is that simple.
Again post a dwg !.
