help presetting state of Visual Styles Manager
Autocad Architecture 2008
i would like to pre-set the state of the visual styles manager. i can't seem
to find the docked stated, autohide, etc in the registry. i did find it in
the exported profile...
Orientation="-1" AllowDocking="1">
Width="315" Height="614"/>
Height="300" MRUDockID="0"/>
ActivePaletteIndex="0" TitleBarLocation="0" AutoRollup="1" Name="VISUAL
STYLES MANAGER" Style="46" Opacity="100" Visible="0"/>
PaletteStyle="0"/>
using lisp, is it possible to send this info to acad to change the current
state of the manager. i don't care if it needs to be in a different syntax
than the xml above.
FWIW, the state i'm trying to set will be constant.
thank you.
Daron
Later, back at the Hall of Justice.....
The XML file where the data is stored is here:
(strcat
(getvar "roamablerootprefix")
"Support\\Profiles\\FixedProfile.aws"
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
"Daron Denton" wrote in message news:[email protected]...
PaletteStyle="0"/>
than the xml above.
thank you.
Daron
thank you.
but my question remains...
> to change the current state of the manager.
Daron
thank you.
