Help Needed lisp Routine for Creating 3D Polylines with Specified Slope"
libarraSCXGZ
Message 1 of 90
libarraSCXGZ
Hi everyone,
I need to develop a LISP routine that allows creating a 3D polyline with a user-specified slope. The goal is for the user to select a starting point, and then the polyline should continue along the surface, following the slope until it reaches a point where the maximum slope at that point is less than the design slope.
I have to carry out feasibility studies for roads and irrigation canals, and it is tedious to do it manually.
Here is a reference of what I need to do:
https://filesnj.carlsonsw.com/mirror/manuals/Carlson_2007/online/index.html?page=source%2FSite_Road_...
Could you help me with some basic LISP code to help me study and move forward with this? My knowledge of LISP is basic, but any help would be appreciated.
Replies (89)
Message 81 of 90
autoid374ceb4990
@leeminardi
When you come out with your new version could you add a line that prints the slope in % (or angle) of the 3DFACEs?  This would be the slope (or angle) of the 3DFACE in relation to a flat plane.  I have some 'C' code that I created to do this, but I am not sure if my slope calculation is correct.  Any assistance would be appreciated.
Message 82 of 90
leeminardi
@autoid374ceb4990
I will add some code to output face slopes but I assume you would like a way to correlate those values with specific 3dfaces.  What dd you have in mind?
In the meantime I quickly (limited testing) wrote the following to output the slope % and angle.  For 3dfaces that are near of precisely vertical the output will have very large numbers.  A vertical face has an infinite slope and a 90° angle.
(defun c:FaceSlope (/ ss facename facedate A B C Normal slopeVector slopeFace ang )
; Calculates and displays the slope of a 3DFACE as a percent and angle.
; L. Minardi 9/6/2024
  (setq	ss	 (ssget '((0 . "3DFACE"))) ; get data for 3Dface
	faceName (ssname ss 0)
  (setq faceData (entget faceName))
  (setq	A      (cdr (assoc 10 faceData)) ;three corners of the 3DFACE
	B      (cdr (assoc 11 faceData))
	C      (cdr (assoc 12 faceData))
	Normal (cross (mapcar '- B A) (mapcar '- C B))
  (setq slopeVector (cross Normal (cross Normal '(0 0 1))))
  (if (equal (caddr slopeVector) 0.0 0.000001)
    (setq slopeFace 0)
    (progn
      (setq slopeFace
	     (abs
		 (caddr slopeVector)
		 (distance '(0 0 0)
			   (list (car slopeVector) (cadr slopeVector) 0.0)
  (setq ang (/ (* (atan slopeFace) 180.) pi))
  (setq m (strcat "Face slope = " (rtos (* 100 slopeface) 2 2) "%"))
  (princ m)
  (setq m (strcat "\nFace slope angle = " (rtos ang 2 2) "°" ))
  (princ m)
  (princ)
;;; Compute the cross product of vectors a and b
(defun cross (a b / crs)
  (setq	crs (list
	      (- (* (nth 1 a) (nth 2 b))
		 (* (nth 1 b) (nth 2 a))
	      (- (* (nth 0 b) (nth 2 a))
		 (* (nth 0 a) (nth 2 b))
	      (- (* (nth 0 a) (nth 1 b))
		 (* (nth 0 b) (nth 1 a))
	    )				;end list
  )					;end setq c
lee.minardi
Message 83 of 90
autoid374ceb4990
@leeminardi:
Thanks, that code works great.  I only need to do one triangle at a time to check against my code.
Good work!
Message 84 of 90
leeminardi
Attached is a more reliable version of the program.  I added the option of letting the user specify whether they want a left or right bias when finding the path of constant slope.  In the image below the red line is a path of 20% grade with a left bias and the green a right bias.  The magenta and yellow lines are 10% grades.
(defun c:SpecSlope (/ designSlope p pStart ss faceName faceData A B C Normal slopeVector slopeFace
		    err gamma q qList pLL pUR face1 face2 x)
; Creates a path along a collection of 3d faces of user defined slope.
; The path is defined by individual line segments.
; User input:
;   Design slope, default = 0.2 (20%)
;   Point on edge of a 3dface
;   Selection of the 3dface with the point
; Fixes in v.02
;   1. Fixed bug that restricted slope to 0.2
;   2.  A 3dpoly is created.
; Fixes in v.05
;   1. Face selection error solved by add zoom to q after each iteration.
;   2.  Zooms to stating point at end of execution.
; Issues
;   1. Does not handle case of path leading to the vertex of several 3dfaces.
;   2. User control of which of 2 valid directions to take is not provided.
; L. Minardi 9/7/2024  v5
(setq k 1) ; used for debugging
(setq designSlope (getreal "\nEnter slope, (e.g. .2 = 20%): "))
(if (not designslope)
  (setq designslope 0.2)
(initget "Left Right")
(if (null
      (setq bias (getkword
		   "\nChoose path direction bias [Left/Right] <Left>: "
  (setq bias "Left")
(setq p	     (getpoint "\nEnter start point on the edge of a face. ")
      pStart p
(command "point" "_non" p)
(princ "\n Select the 3dface of the stating point: ")
      Qlist    (list p)
(setvar "cmdecho" 0)
(while faceName
		  (setq	faceData    (get_face_data faceName designSlope)
			A	    (nth 0 faceData)
			B	    (nth 1 faceData)
			C	    (nth 2 faceData)
			Normal	    (nth 3 faceData)
			slopeVector (nth 4 faceData)
			slopeFace   (nth 5 faceData)
			err	    (nth 6 faceData)
  (if (= err 1)
    (progn (princ 	"\nNoSolution, 3dFace slope is less than maximum slope.\nSlope  = " )
      (princ slopeface)
      (setq faceName nil)
		(progn
		  (setq gamma  (- (acos (/ designSlope slopeFace))))
		  (if (equal (strcase bias) "RIGHT")
		    (setq gamma (* -1. gamma))
		  ;;;(princ "\ngamma = ")
		  ;;;(princ gamma)
		  ;;;(princ "\nk = ")   (princ k) 	  (setq k (+ k 1))
		  (setq q (FindQ p A B C slopeVector designSlope gamma))
		  (if q					; [1]
		    (progn
		        (setq qList (append qList (list q)))
		      (command "_zoom" "c" q 5)
		      (setq ss (ssget "_c" q q '((0 . "3dface"))))
		      (setq sslen (sslength ss))
		      (cond
			((= ss nil)
			 (progn
			   (princ "\nERROR! No selection at Q.")
			   (command "_circle" "_non" q 0.2); draw circle to show error location
			   (setq facename nil)		; to terminate while
			((/= sslen 2)
			 (progn
			   (princ "\Other than two 3dfaces selected at Q.")
			(progn
			 (setq face1 (ssname ss 0)
			       face2 (ssname ss 1)
			 (if (equal face1 facename)
			   (setq faceName face2)
			   (setq faceName face1)
			 (setq p q)
		      )					; end cond
		    )					; end progn no errors
		  )					; end if  [1]
		)					;end progn
    )	; end if
) ; end while
 (command "_3dpoly"  )			;start 3dpoly command
  (while (= (getvar "cmdactive") 1)	;while a command is running loop (it is because we haven't entered any points)
    (repeat (setq x (length qList))
      (command "_non" (nth (setq x (- x 1)) qList))
    )					;end repeat
    (command "")			;end 3dpoly
  (command "_zoom" "c" pStart 5)
  (setvar "cmdecho" 1)
  (princ "\nDONE!")
  (princ)
(defun FindQ ( p v1 v2 v3 slopeVector designSlope gamma / q s q1 q2 q3 )
; determine up hill point at slope = designSlope
; p = start point
; v1, v2, v3 = 3dface vertices
; slopeVector = slope vector of 3dface that points in the uphill direction
; designSlope = desired slope of line  (e.g., 0.2 = 20%)
; gamma = angle between the projection of slopeVector to xy plane and the
;         direction of the designSlope line projected to the XY plane
  (setq	Q
	 (mapcar
	   p
	   (list
	       (* (car slopevector) (cos gamma))
	       (* (cadr slopevector) (sin gamma))
	       (* (car slopevector) (sin gamma))
	       (* (cadr slopevector) (cos gamma))
	     (*	designSlope
		(sqrt
		  (+ (expt (car slopevector) 2) (expt (cadr slopevector) 2))
; define vector from p towards q
(setq s (mapcar '+ p (mapcar '* (mapcar '- q p) '(1000 1000 1000))))
(if s
(progn
; get the three intersections of design slope vector with face edges
  (setq q1 (inters v1 v2 p s nil)
      q2 (inters v2 v3 p s nil)
      q3 (inters v3 v1 p s nil)
; check if q1, q2, q3, are on an edge segment of face
; set qn to nil if not on line segment
  (if (not (equal (distance v1 v2)
		  (+ (distance v1 q1) (distance q1 v2))
		  1e-5
      )	; q1 is on line segment?
    (setq q1 nil) ; q1 is not on line segment
  (if (not (equal (distance v2 v3)
		  (+ (distance v2 q2) (distance q2 v3))
		  1e-5
      )					; q2 on line segment?
    (setq q2 nil)
  (if (not (equal (distance v3 v1)
		  (+ (distance v3 q3) (distance q3 v1))
		  1e-5
      )					; q3 on line segment?
    (setq q3 nil)
					;set q to nil if q coincident with p
  (if (equal q1 p 0.001)
    (setq q1 nil)
  (if (equal q2 p 0.001)
    (setq q2 nil)
  (if (equal q3 p 0.001)
    (setq q3 nil)
					;  set q to only non-nil qn
  (cond
    (q1 (setq q q1))
    (q2 (setq q q2))
    (q3 (setq q q3))
) ; end s true
;  ?????????????? test needed if Q lower than P???????
(progn  ; s = nil
(princ "\nIntersection not found.\n")
(command "_circle" "_non" p 0.2)
(setq q nil)
  ) ; end if s
(defun get_face_data (faceName designSlope / A B C Normal slopeVector slopeFace designSlope faceData err)
; Given a face name determine its vertices, normal vector, slope vector, slope, and error if any.
; Returns a list with the data
; err = nil, no errors
; err = 1, no solution, the slope of the face is less than the design slope
	err    nil
  (if (< (caddr slopeVector) 0.)	; make sure normal has a + z coorindate
    (setq slopeVector (mapcar '* '(-1 -1 -1) slopeVector))
  (setq	slopeFace
	   (caddr slopeVector)
	   (distance '(0 0 0)
  (if (< slopeface designSlope)
    (setq err 1)
  (setq facedata (list A B C Normal slopeVector slopeFace err))
; Unit vector of v
(defun unitvec (v / x)
  (setq	x (distance '(0 0 0) v)
	x (mapcar '/ v (list x x x))
;; ArcCosine  -  Lee Mac
;; Args: -1 <= x <= 1
(defun acos ( x )
    (if (<= -1.0 x 1.0)
        (atan (sqrt (- 1.0 (* x x))) x)
; dot product of vectors a and b
(defun dot (a b / dd)
  (setq dd (mapcar '* a b))
  (setq dd (+ (nth 0 dd) (nth 1 dd) (nth 2 dd)))
);end of dot
;;; cross product of vectors a and b
  (setq	crs (list
	    )				;end list
  )					;end setq c
)					;end cross
;; Tangent  -  Lee Mac
;; Args: x - real
(defun tan ( x )
    (if (not (equal 0.0 (cos x) 1e-10))
        (/ (sin x) (cos x))
; test if 3 points are collinear.
;; Collinear-p  -  Lee Mac
;; Returns T if p1,p2,p3 are collinear
(defun Collinear-p (p1 p2 p3)
   (lambda (a b c)
     (or
       (equal (+ a b) c 1e-8)
       (equal (+ b c) a 1e-8)
       (equal (+ c a) b 1e-8)
    (distance p1 p2)
    (distance p2 p3)
    (distance p1 p3)
; some function to help debugginh
(defun c:faceName (/)
  (setq	ss
  (entget faceName)
  (princ facename)
  (princ)
(defun c:GetSlope (/ s p1 p2 data d slope)
  (setq	s     (ssget '((0 . "line")))
	data  (entget (ssname s 0))
	p1    (cdr (assoc 10 data))
	p2    (cdr (assoc 11 data))
	d     (distance	(list (car p1) (cadr p1))
			(list (car p2) (cadr p2))
	slope (/ (- (caddr p2) (caddr p1)) d)
  (princ "\nSlope = ")
  (princ slope)
  (princ)
lee.minardi
Message 85 of 90
autoid374ceb4990
@leeminardi:
I tried your version 6 and it works great.  I do have a few "user interface" suggestions:
1. The Entered slope defaults to 20%.  Once the desired slope is entered it would be nice if it is retained as the default.
2. If possible display the R-L options as lines in the first 3DFACE and let the user pick.
3. Save the current VIEW before the ZOOM commands start and restore the  VIEW when finished.
Excellent work.  I wonder if the OP has tried it?
Charles
Message 86 of 90
john.uhden
@leeminardi & @autoid374ceb4990 ,
I finally got'er done.
The attached file contains three (3) AutoLisp commands:
  1. 3DFace2Profile (3DF2P)
  2. Grade
  3. SlopeMap (SM)
Just finished the last one today.  It creates a color coded bylayer 2DSolid for every face selected in the following format:
(setq layers
  (list
   '("0-2%" 51)
   '("2-5%" 31)
   '("5-10%" 30)
   '("10-20%" 1)
   '("20%+" 6)
where the first item in each pair is the layer name (self-explanatory) and the 2nd is the layer color.
Go ahead and change the colors to your liking (I'm really not pleased with my selection).
Don't change the layer names.
John F. Uhden
Message 87 of 90
leeminardi
@autoid374ceb4990 wrote:
@leeminardi:
Charles
Charles,
Version 7 addresses #1 and #3. I'll leave #2 for someone else.
Lee
		    err gamma q qList pLL pUR face1 face2 x startView)
; User input:
; Fixes in v.02
; Fixes in v.05
;  Fixes in v.07
;   1. Restores initial view when done.
;   2. Both slope and bias may be set modally by user/
; Issues
; L. Minardi 9/9/2024  v7
(command "-view" "s" "startView")
(setq designSlope (getvar 'userr4 ))
(if designSlope
  (progn
    (setq msg (strcat "\nEnter design slope ratio <"
		      (rtos designSlope 2 3)
	  x   (getreal msg)
    (if	(not x)
      (setq x designSlope)
  (setq	msg (strcat "\nEnter design slope ratio <0.20>: "
	x   (getreal msg)
(setvar 'userr4 x)
(setq designSlope x)
; prompt user for left ot right bias and make it modal
(setq x (getvar 'users4))
(cond
  ((or
     (equal x "")
     (equal x "LEFT")
   (cond
     ((equal bias nil) (setq bias "LEFT"))
     ((equal (strcase bias) "LEFT") (setq bias "LEFT"))
     ((equal (strcase bias) "RIGHT") (setq bias "RIGHT"))
  ((equal (getvar 'users4) "RIGHT")
		"\nChoose path direction bias [Left/Right] <Right>: "
   (cond
     ((equal bias nil) (setq bias "RIGHT"))
(setvar 'users4 bias)
      pStart p
      Qlist    (list p)
(while faceName
			A	    (nth 0 faceData)
			B	    (nth 1 faceData)
			C	    (nth 2 faceData)
  (if (= err 1)
    (progn (princ 	"\nPath ends, 3dFace slope is less than maximum slope.\nSlope  = " )
      (princ slopeface)
      (setq faceName nil)
		(progn
		  ;;;(princ gamma)
		  (if q					; [1]
		    (progn
		      (cond
			((= ss nil)
			 (progn
			   (princ "\nERROR! No 3DFACE selection at path end.")
			((/= sslen 2)
			 (progn
			   (princ "\nERROR! Other than two 3DFACES selected at path end.")
			(progn
			       face2 (ssname ss 1)
			 (setq p q)
		      )					; end cond
		  )					; end if  [1]
		)					;end progn
    )	; end if
) ; end while
    )					;end repeat
  ;(command "_zoom" "c" pStart 5)
  (command "-view" "r" "startView")
  (command "-view" "d" "startView")
  (princ "\nDONE!")
  (princ)
; p = start point
  (setq	Q
	 (mapcar
	   p
	   (list
	     (*	designSlope
		(sqrt
(if s
(progn
		  1e-5
		  1e-5
    (setq q2 nil)
		  1e-5
    (setq q3 nil)
    (setq q1 nil)
    (setq q2 nil)
    (setq q3 nil)
  (cond
    (q1 (setq q q1))
    (q2 (setq q q2))
    (q3 (setq q q3))
) ; end s true
(progn  ; s = nil
(setq q nil)
  ) ; end if s
	err    nil
  (setq	slopeFace
	   (caddr slopeVector)
	   (distance '(0 0 0)
    (setq err 1)
; Unit vector of v
(defun acos ( x )
    (if (<= -1.0 x 1.0)
);end of dot
  (setq	crs (list
	    )				;end list
  )					;end setq c
)					;end cross
;; Args: x - real
(defun tan ( x )
        (/ (sin x) (cos x))
  (setq	ss
  (entget faceName)
  (princ facename)
  (princ)
  (princ slope)
  (princ)
lee.minardi
Message 88 of 90
leeminardi
@john.uhden
I checked out Slope Map and it gives accurate results.  Congrats.  Did you consider just hatching the 3dfaces rather than making solids? BTW, the Mass Properties command does not recognize them as solids.
As for colors, try ROYGBIV!
I'm curious, I assume the (setq OK 1), (set ok 2), ... statements are for debugging.  I would thinkk setting break points is much easier.
Lee
lee.minardi
Message 89 of 90
autoid374ceb4990
@leeminardi:
I tried your v7 and I like the changes in data entry.  I did run into a small problem, probably because of the age of my AutoLISP.
I had to change the line  (command "-view" "s" "startView") to (command "view" "s" "startView" "")
I also had to change all the lines with 'users4 to "users4".
Message 90 of 90
john.uhden
@leeminardi ,
Wish I had known that color convention first.  I had to Google it.
Sounds like I hadn't removed all those (setq ok #).
It's my old way of zeroing in on errors.  Never got used to VLIDE except for creating .FAS and .VLX files.
John F. Uhden
