Help in converting adjoining multiple "solids" into a single "solid"
Jonathan.Gray68UQW
Message 1 of 12
Jonathan.Gray68UQW
Hey all,
I had a bunch of solid hatches that I converted into "solid" objects, not solid hatches using the lisp supplied here https://forums.autodesk.com/t5/autocad-forum/combining-object-into-single-solid-object/td-p/6447660
the problem that occurs is that it takes a single solid hatch and will break it up into multiple "solid" entities.
My question now is, would anybody be willing to help me with a method to combine multiple "solids" into a single "solid" if the "solids" touch/adjoin each other?
Replies (11)
Message 2 of 12
pendean
Community Legend
Community Legend
UNION command?
Message 3 of 12
Jonathan.Gray68UQW
Hey, thank you for trying to help me! I tried the "union" command and keep getting this error "At least 2 solids, surfaces, or coplanar regions must be selected."
Message 4 of 12
pendean
Community Legend
Community Legend
Can you share your DWG file with us please?
Message 5 of 12
Jonathan.Gray68UQW
Not a problem.
Message 6 of 12
Jonathan.Gray68UQW
Hey, so based on that attached drawing I would love to have about 5 total solid areas if possible, right now I have 43.
Message 7 of 12
ronjonp
Do these have to be solids?  A solid hatch picking an internal point works. You get 7 total.
Message 8 of 12
Jonathan.Gray68UQW
Hey I hate it that they have to be solids... The solid part comes into play in a future routine that I run.
Message 9 of 12
Kent1Cooper
Unfortunately, that's not possible with the 2D SOLID object type, which can have only 3 or 4 corners/edges [when it has 3 corners, it actually has 4, but the 4th one is put at the same location as the 3rd one].
EDIT:  A thought --  What does the "future routine" that you run do?  Might there be another way to accomplish it from your original Hatch patterns [or some other single-entity boundary objects such as Polylines or Regions], and skip the middle-man of the multiple-Solids conversion?
Kent Cooper, AIA
Message 10 of 12
ronjonp
As @pendean mentioned use the union command. The step you are missing is converting to regions first.
Message 11 of 12
Kent1Cooper
[See Message 8, unless there's some way that their routine that uses Solids can be made to do its thing otherwise.]
Kent Cooper, AIA
Message 12 of 12
ronjonp
I did see that post, just offering another solution. Until the OP describes the next step ( which I'm guessing could be optimized ) we're just playing a guessing game 🙂
