Export Layouts to DWGs with pop-up Dialog box -LISP
Millwood-k
Message 1 of 18
Millwood-k
Hi, Hope you guys doing well,
I am a beginner in Autolisp.
I found a handy simple lisp routine in the forum, about exporting Layouts to separate DWGs (to the model space) which I was looking for; however it send them (separate DWGs) automatically to the same location where the main drawing is located,
My question:
Can someone show me how to include an option which allowed the dialog box pops up?
Appreciation
Here is the lisp routine as-is:
(defun c:test ( / BASE LST OLD_DIA)
     (setq old_dia (getvar 'FILEDIA)
base (strcat (getvar 'DWGPREFIX) (vl-filename-base (getvar 'DWGNAME)))
    (setvar 'FILEDIA 0)
    (setq lst (layoutlist))
    (foreach l lst
    (command "_.ctab"
       l
      "exportlayout"
      (strcat base "-" l)
     (setvar 'FILEDIA old_dia)
    (princ)
Replies (17)
Message 2 of 18
Moshe-A
@Millwood-k  hi,
here is my fix. it depends on Lee's Mac (LM:BrowseForFolder) function (thank you Lee)
download this lisp function >> from here <<  and save it under your lisp library folder under Support Files Search path.
untested
enjoy 😀
moshe
(defun c:test ( / base old_dia)
 (if (null LM:browseforfolder)
  (load "BrowseForFolderV1-3")
 (if (setq base (LM:browseforfolder "Select a folder" "C:\\" 0))
  (progn
   (setq old_dia (getvar 'FILEDIA))
   (setvar 'FILEDIA 0)
  ; (setq base (strcat (getvar 'DWGPREFIX) (vl-filename-base (getvar 'DWGNAME))))
   (setq base (strcat base (vl-filename-base (getvar 'DWGNAME))))
   (foreach lay (layoutlist)
    (command "_.ctab" lay "exportlayout" (strcat base "-" lay))
  ); progn
 ); if
 (princ)
Message 3 of 18
Millwood-k
Thanks Moshe-A,
I copied it in my visual lisp window (by typing VLIDE in the command text, but I didn't work I got in return in the command line
; error: LOAD failed: "BrowseForFolderV1-3"
Message 4 of 18
@Millwood-k  "BrowseForFolderV1-3" Must be loaded on your drawing.
Message 5 of 18
Millwood-k
I uploaded the LM:browseforfolder support. but for some reason I am not permitted to use the C volume on my desktop, however I replaced it by the D volume, but it did not recognized it.
(if (setq base (LM:browseforfolder "Select a folder" "D:\\" 1))
(progn
(setvar 'FILEDIA 0)
); progn
); if
(princ)
Message 6 of 18
Moshe-A
@Millwood-k ,
(setq base (LM:browseforfolder "Select a folder" "c:\\" 1))
how the last argument became 1,  when it should be 0?!
moshe
Message 7 of 18
dbhunia
@Millwood-k  & @Moshe-A  I would like to replace the line ......
with
(setq base (strcat base "\\" (vl-filename-base (getvar 'DWGNAME))))
If user wanted to select any other folders also except root directory.....
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 8 of 18
Millwood-k
@Moshe-A@dbhunia
Wow, thanks guys
When replacing the zero value C:\\" 0 by one C:\\" 1  it export them beside the destination. But
When adding "\\" as @dbhunia showed it just worked perfect.
Appreciation😀
Here is the the final edition:
(defun c:ld ( / base old_dia)
(if (setq base (LM:browseforfolder "Select a folder" " C:\\" 1))
(progn
(setvar 'FILEDIA 0)
); progn
); if
(princ)
Message 9 of 18
Millwood-k
@dbhunia
I would like to have another option about the file name
in the actual routine it is like this : main drawing name -layer name.dwg
I would like to have it like : layer name_ACAD_2019.dwg
so I tried this below but it didn't work:
(command "_.ctab" lay "exportlayout" (strcat lay "_ACAD_2019"))
Message 10 of 18
dbhunia
Try like this.......
If you need "layout name_ACAD_2019.dwg"
	(progn
		(setvar 'FILEDIA 0)
			(command "_.ctab" lay "exportlayout" (strcat base "\\" lay "_ACAD_2019"))
	); progn
); if
(princ)
But I prefer.......
	(progn
		(setvar 'FILEDIA 0)
			(command "_.ctab" lay "exportlayout" (strcat base "_" lay "_ACAD_2019"))
	); progn
); if
(princ)
Debashis Bhunia
Message 11 of 18
Millwood-k
Thanks to ALL of you guys
Nice effort and
I appreciate giving your time to others
Message 12 of 18
Millwood-k
Hello @dbhunia, hope you and all doing well,
I remember helping me with Layout-to-DWG,
This is if we need "layout name_ACAD_2019.dwg"
	(progn
		(setvar 'FILEDIA 0)
	); progn
); if
(princ)
The question how to get rid of "_ACAD_2019" ?, which means we need only the layout name to be showed.
Thank you in advance.
Message 13 of 18
Millwood-k
I remember the lisp routine for export layouts to separate dwgs,
Is it possible to adapt this script to publish (separate PDFs) with the same possibility to add extension.
thanks
Message 14 of 18
Sea-Haven
I have posted many times the plot Layout range lisp to here search for it, "plotA3Pdfrange.lsp"
Maratovich has a good extensive plot program as well again search.
Message 15 of 18
maratovich
@Millwood-k  написал (-а):
Try this - AutoRunLisp
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Message 16 of 18
Millwood-k
Yes I saw that it's very useful, however in my case I d like a simple script for some reason.
Message 17 of 18
m.mazaz
Hi I I make a small change to the original code to make it show only the layout name only
and btw I think it is better to save the drawings in the same path 🙂
have fun
base (strcat (getvar 'DWGPREFIX) )
(setvar 'FILEDIA 0)
(foreach lst (layoutlist)
(command "_.ctab"
lst
"exportlayout"
(strcat base "" lst)
(princ)
Message 18 of 18
Sea-Haven
Early in your posts you refer to not finding code, you should make yourself a directory called say D:\Mylisps put all your lisps in there type Config select Files and add D:\mylisps to your search path and trusted paths, much easier than the desktop.
Here is plotpdfa3range.
