help - draw an adjustable frame
mihai_bantas
Message 1 of 8
mihai_bantas
Hello everyone, I have to draw an adjustable frame (automatic) with a lisp code.
The idea is simple (so I think)....I have a fixed point x, y (0, 900) where I need to insert the frame, but the frame must follow my last vertical line of color 8
I've attached a DWG file detailing my requests.
I remain deeply grateful for any suggestion of code or income support....
Replies (7)
Message 2 of 8
stevor
Here is a start, modified from a past. The presets match your sample DWG.
S
Message 3 of 8
CodeDing
Assuming the profile line is a polyline each time, here's something quick and easy. It doesn't adjust for OSMODE or ERRORS. It uses a table and tablestyle to adjust your needs as necessary. Just a thought. Attached is a Table Style to insert into drawing, edit as you like.
Best,
~DD
(defun c:EZTABLE (/ entPro MyTable HdistPro)
;insert table from ProfileTable to adjust to length of profile polyline
(setq entPro (entsel "\nSelect Profile Polyline"))
(vl-load-com)
(setq HdistPro (- (car (vlax-curve-getEndPoint (car entPro))) (car (vlax-curve-getStartPoint (car entPro)))));gethorizontal distance of profile polyline)
(command "-table" "2" "2" "s" "ProfileTable" (list (- (car (vlax-curve-getStartPoint (car entPro))) 26.5) 900.0));create table (2 cols / 2 "rows" (1 header 1 title))(tablestyle)(inspoint)
(command "chprop" (entlast) "" "LA" "Defpoints" "");change layer to defined place
(setq MyTable (vlax-ename->vla-object (entlast)))
(vla-setcolumnwidth MyTable 0 23.0);Col 1 width
(vla-setcolumnwidth MyTable 1 (+ HdistPro 7));Col 2 width
(vla-setrowheight MyTable 0 5.3482);Row 1 height
(vla-setrowheight MyTable 1 9.6518);Row 2 height
(vla-setrowheight MyTable 2 5.0);Row 3 height
(vla-setrowheight MyTable 3 5.0);Row 4 height
(vla-settext MyTable 0 0 "Text 1");(row/col)(row text)
(vla-settext MyTable 1 0 "Text 2");(row/col)(row text)
(vla-settext MyTable 2 0 "Text 3");(row/col)(row text)
(vla-settext MyTable 3 0 "Text 4");(row/col)(row text)
(princ)
);defun
Message 4 of 8
mihai_bantas
Thanks a lot dkdeterding, but I have only one request if you can select the automatic profile line by LAYER NAME or COLOR.
I tried to change the code with     (setq entPro (ssget "x" '((0 "LWPOLYLINE")(8 "Lung-teren"))))
... but it did not work
Anyway, thank you for the answers dkdeterding and stevor
Message 5 of 8
CodeDing
I believe those are supposed to be dotted pairs. Try..
~DD
(setq entPro (ssget "_x" '((0 . "LWPOLYLINE") (8 . "Lung-teren"))))
Message 6 of 8
ВeekeeCZ
~DD
You're definitely right. But keep going... 😉
- (ssget) returns selection set, but the original code threads entPro as a pair of entity name and sel point.
- would be (always) ss a set of single entity or possibly more?
- selection (_x) might be limited for current space (model)....
Edit: Oh, just found that you're the author of the original code just you've changed the nick name... sorry for interrupting your thread.
Message 7 of 8
CodeDing
Diggin the name change! lol
I love the input! I'm by no means an expert, rather just learning actually, so to get reviewed further is very useful to me! Thank you for adding these.
Best,
~DD
Message 8 of 8
CodeDing
I hadn't tested the updated code I sent. I have edited the original code to what I believe you're looking for. With helpful guidance from BeeKeeCZ!
THIS CODE IS FOR THE ASSUMPTION THAT THIS POLYLINE IS THE ONLY POLYLINE ON THIS LAYER, unless you know whether it was the first or last (or nth) polyline drawn on that layer EVERY time.. If not, at that point it would be just as easy to select the line.
Best,
~DD
(defun c:EZTABLE (/ entPro MyTable HdistPro OldOS)
(setq OldOS (getvar "Osmode"));Store snap mode
(setvar "Osmode" 0);turn off snap
(setq entPro (ssname (ssget "X" '((0 . "*POLYLINE") (8 . "Lung-teren"))) 0));Look for all polylines on that layer
(vl-load-com)
(setq HdistPro (- (car (vlax-curve-getEndPoint entPro)) (car (vlax-curve-getStartPoint entPro))));get horizontal distance of profile polyline ("car" not needed as we have stored entity name already)
(command "-table" "2" "2" "s" "ProfileTable" (list (- 0.0 26.5) 900.0));create table (2 cols / 2 "rows" (1 header 1 title))(tablestyle)(inspoint)
(setvar "Osmode" OldOS)
(princ)
);defun
