HATCH SOLID
HATCH SOLID
sigmmadesigner
Message 1 of 18
HATCH SOLID
sigmmadesigner
WHY THIS CONFIGURATION DOES NOT ACCEPT SOLIDS
;; DRAW
(command "_.PLINE" ptBase1 topoPt ptBase2 "C")
(setq triEnt (entlast))
(command "_.HATCH" "ANSI31" ".001" "0" triEnt "")
(setq hacEnt (entlast))
(command "_.CHPROP" hacEnt "" "Color" "30" "")
Replies (17)
Message 2 of 18
cadffm
Because you don't have a hatch pattern with name "Solids" ?
SOLID
And I guess, -hatch don't asking for an angle.
Set CMDECHO to 1
Run your (command...) with SOLID
and press [F2]
and you can see what the problem is.
Share a screenshot if you can not see the issue.
Sebastian
Message 3 of 18
ВeekeeCZ
...nor the scale
(command "_.HATCH" "solid" triEnt "")
Message 4 of 18
komondormrex
i think
(command-s "_.HATCH" "solid" ".001" "0" triEnt "")
will do
Message 5 of 18
paullimapa
FYI: Here's another way to change the hatch color:
(command "_.Hatchedit" (entlast) "_Co" "30")
Paul Li
IT Specialist
@The Office
Message 6 of 18
cadffm
The original code works, so I guess sigmmadesigner ised the wrong pattern name
Sebastian
Message 7 of 18
sigmmadesigner
Hello everyone,  @cadffm @paullimapa @komondormrex @ВeekeeCZ
I tried, all the possibilities posted last I even joked.. it's just add solido that the function gives an error.
Thank you all for contributing!!!
Message 8 of 18
paullimapa
did you try changing the code to what both @cadffm & @ВeekeeCZ mentioned:
Paul Li
IT Specialist
@The Office
Message 9 of 18
paullimapa
also try it with an underscore in front of solid:
(command "_.HATCH" "_solid" triEnt "")
Paul Li
IT Specialist
@The Office
Message 10 of 18
cadffm
Your original hatch-codeline should works with solid.
I miss your Textscreen [F2] screenshot, while cmdecho is 1
Sebastian
Message 11 of 18
sigmmadesigner
THIS WAS THE SOLUTION
command "_.PLINE" (car rect1) (cadr rect1) (caddr rect1) (cadddr rect1) "C")
(setq rectEnt1 (if (/= (entlast) entBefore) (entlast) nil))
(if rectEnt1 (progn (command "_.CHPROP" rectEnt1 "" "Color" "40" "")
(command "_.HATCH" "SOLID" rectEnt1 "")
(setq hatch1 (entlast))
(command "_.CHPROP" hatch1 "" "Color" "40" ""))
    (princ "\n ERROR HATCH SOLID"))
Message 12 of 18
paullimapa
so isn't your revised line of code:
similar to what we posted:
triEnt was the variable you used in your OP:
Paul Li
IT Specialist
@The Office
Message 13 of 18
komondormrex
watch the gif
Message 14 of 18
sigmmadesigner
lsp only accepted to apply solid hatching if with
with respect to rectEnt1, triEnt were the types of objects that would receive the function, rectangles and triangles.
Message 15 of 18
sigmmadesigner
what madness, in msg 7/14 changing the type to stop programming
Message 16 of 18
paullimapa
looks like we are not seeing the entire code because entBefore is not defined in the code you've posted.
Paul Li
IT Specialist
@The Office
Message 17 of 18
sigmmadesigner
Hi, @paullimapa
There is actually no line above this fragment, which means a variable that receives the selection of what was previously created and stores it, so that it can later recognize the limits and place the solid hatch, as exemplified by @komondormrex the solid hatch depends on you determining the limit points, and the entBefore function does this storage so that the solid hatch is applied. That's why in my video when I use the function directly it gives an error, and with this proposition I store the object to apply the solid.
I don't know if I explained it well.
example:
;points of the rectangle
(setq rectPts (list   (polar (polar pt ra(/ fa -2)) (+ ra (/ pi 2)) (/ FE_width 2))
(polar (polar pt ra(/ fa 2))  (+ rectAngle (/ pi 2)) (/ fw2))
(polar (polar pt ra(/ fa 2))  (+ rectAngle (/ pi 2)) (/ fw-2))
(polar (polar pt ra(/ fa -2)) (+ rectAngle (/ pi 2)) (/ fw-2))))
;; Stores the last entity before the PLINE command
  (setq entBefore (entlast))
;; Draw the strip rectangle (closed polyline)
  (command "_.PLINE" (car rectPts) (cadr rectPts) (caddr rectPts) (cadddr rectPts) "C")
;; Stores the last created entity (strip rectangle)
  (setq entAfter (entlast))
  (setq rectEnt (if (/= entBefore entAfter) entAfter nil))
;; If rectangle was created, apply color and hatch properties
  (if rectEnt (progn  (command "_.CHPROP" rectEnt "" "Color" "253" "")
  (command "_.HATCH" "SOLID" rectEnt "")           ;; Hatch solid
  (command "_.CHPROP" hacEnt "" "Color" "253" "")  ));; Hatch color same contour
ent + Before
Message 18 of 18
paullimapa
So it sounds like your closed pline creation has a possibility of failing which is why you've added the test to see if the last entity is different than your previous last entity. But if there's no problems with the closed pline being generated then the same hatch command works.
Paul Li
IT Specialist
@The Office
