Grread polyline draw with arc option
office
Message 1 of 22
office
I made a lisp that draws a polyline with grread.
I want to switch to arc while drawing the polyline with my grread function.
How can it be made to be the same as the autocad polyline draw arc option while drawing a polyline?
Replies (21)
Message 21 of 22
office
If you started the polyline with an with arc did not work.
Here is attached the edited lisp.
Message 22 of 22
ronjonp
Glad you found an answer 🙂 Remember to cleanup your variables after use
[CHECKING TEXT <Untitled-0> loading... SELECTION]
; === Top statistic:
; Global variables: (STARTPOINT)
; Function definition (with number of arguments): ((*ERROR* . 1) (C:TEST . 0))
; Global variables: (CARGR GRPOINT GRREAD_ INPUTCHARCODE INPUTTEXT ISARCON ISENDOFGRREAD ISFOUNDOSNAP MAINPROMPTTEXT OSNAPPOINT PLINEBULGELIST PLINECOORDLIST PLINEVLA PREVGRPOINT)
; Function definition (with number of arguments): ((STARTPOLYGRREAD . 1))
; Global variables: (ISARCON ISFOUNDOSNAP P1 PLINECOORDLIST PLINEVLA)
; Function definition (with number of arguments): ((UPDATEGRDRAW . 2))
; warning: same symbol found before and after / in arguments list: P3
; Global variables: (CHORD D2_3 RETURNBULGE)
; Function definition (with number of arguments): ((GRDRAWARC . 3))
; Function definition (with number of arguments): ((LM:3P->BULGE . 3))
; Function definition (with number of arguments): ((PM_ARC . 3))
; Global variables: (PLINECOORDLIST PLINEVLA)
; Function definition (with number of arguments): ((UPDATEPOLYLINE . 1))
; Global variables: (vlax-vbDouble)
; Function definition (with number of arguments): ((CREATEPOLYLINE . 1))
; Global variables: (ISARCON MAINPROMPTTEXT OPTIONASCIILIST)
; Function definition (with number of arguments): ((CREATEPROMPTTEXT . 0))
; Check done.
