Grab an attribute then use it to turn off a layer
brian_shick
brian_shick
Good morning,
I am very new to LISP and need your help, at this point I can only make minor changes to existing code but a lot of the code still is magic to me.
I have a block "ULTRA INFO" with an attribute "CIRCID" that can be used to help turn off a layer with that name that has "-DATA" added to the end. What I think we need to do is to grab the attribute variable and store it, then add a wild card * to the end, lastly have it turn off a layer with that name.
Here is my thought:
Some how scan the drawing for an attribute named "CIRCID" if it is found store it as "LAName"
Then turn off the layer: (command "-Layer" "off" "(LAName)*" "")
If an attribute named "CIRCID" doe not exist cancel and end the lisp.
Any help possible is greatly appreciated.
Thank you all in advance.
Brian
paullimapa
hmsilva
One way...
(vl-load-com)
(defun c:demo ( / ACTLAY LANAME SS)
 (if (setq ss (ssget "_X" '((0 . "INSERT") (2 . "ULTRA INFO") (66 . 1) )))
    (foreach att (vlax-invoke (vlax-ename->vla-object (ssname ss 0)) 'getattributes)
      (if (= (strcase (vla-get-tagstring att)) "CIRCID")
	(progn
	  (setq	LAName (vla-get-textstring att)
		*adoc* (vla-get-ActiveDocument (vlax-get-acad-object))
		actlay (vla-get-ActiveLayer *adoc*))
	  (vlax-for lay (vla-get-Layers *adoc*)
	    (if (and (wcmatch (strcase (vla-get-name lay)) (strcase (strcat LAName "*")))
		     (not (= (strcase (vla-get-name lay)) (strcase LAName )))
	      (vla-put-LayerOn lay :vlax-false)
  (princ)
HTH
Henrique
_Tharwat
