Getting Visual LISP Error message
Automohan
Message 1 of 8
Automohan
"Save Energy"
Did you find this reply helpful? If so please use the Accept as Solution
Replies (7)
Message 2 of 8
Automohan
Please move this to "Customization"
"Save Energy"
Message 3 of 8
pbejse
Are you saying any lisp files? not a one?  And you were able to open the files before on the same machine?
Could be a corrupted installation?  Before you ask IT to re-install, try first  "Reset settings to default" found at start menu, under your AutoCAD version, usually the last item.
Message 4 of 8
Automohan
Yes, any lisps are not opening, this happens today only after running some of the lisp routines!
I am going through that lisp routines.
previously  also some issue with my AutoCAD startup error, still not Reset !
"Save Energy"
Message 5 of 8
pbejse
Running lisp routines? are they loaded at startup?  Yes, go thorugh all of them. You probably assign a protected symbol as a variable along the way.
And also read this --> About Protected Symbols (AutoLISP)
Tell us how it goes.
Message 6 of 8
Sea-Haven
I use FINDSTR from the CMD of windows its a DOS type command you are in the operating system level in simple terms, Go bottom left Windows type CMD a black screen will appear with say C:
If you know the directory where your startup lisps are then use "findstr"
cd \mydirectory\moredirectory\mylisps
then do FINDSTR ACAD *.lsp it will check all your lisps for "ACAD" and show names.
You need to put the correct path in the CD \ step if you need to change drives do it type 😧 it will go to D drive.
Message 7 of 8
Automohan
I found the word "file is corrupted" then I look into the file path & replace the same file with another PC (same AutoCAD 2017 Civil 3d)
It works !
This happens many times while I found a lisp file !
I am sharing it below . . .   have a look & reply
"Save Energy"
Message 8 of 8
Automohan
https://lispbox.wordpress.com//?s=ETABLE&search=Go
"Save Energy"
