getting a text entity at a point
kpennell
Message 1 of 26
kpennell
Is there any way using 'ssget' that I can get a text entity at a non-specific point?  Like:
(ssget "X" '((0 . "TEXT")(11 318.03737793 9.13950144 0.0)))
Or will I have to retrieve all texts in the drawing, and do a compare?  Like this:
(and (= (cdr (assoc 0 ent1)) "TEXT") (equal (cdr (assoc 11 ent1)) '(318.03737793 9.13950144 0.0) 1e-8))
Replies (25)
Message 21 of 26
john.uhden
I'll raise you a penny.
Do you mean 4 points, or 4 times around?
John F. Uhden
Message 22 of 26
Sea-Haven
Example
(setq p2 (mapcar '+ p1 (list 1 1 0.0))
p3 (mapcar '+ p1 (list -1 1 0.0))
p4 (mapcar '+ p1 (list -1 -1 0.0))
p5 (mapcar '+ p1 (list 1 -1 0.0)))
(setq pts (list pt2 pt3 pt4 pt5 pt2))
(setq ss (ssget "F" pts '((0 . "TEXT"))))
Message 23 of 26
john.uhden
Only one time around? 😁
John F. Uhden
Message 24 of 26
john.uhden
I was thinking over the weekend (scary, eh?)...
that the size of your PICKBOX determines how much drawing area one pick can cover,
and that nentselp doesn't need user input and is not restricted to nested entities.
So I just tested with the following by picking an empty spot in the middle of an MTEXT.
(defun c:test ( / p pick)
  (princ (strcat "\nPICKBOX is starting at " (itoa (getvar "pickbox")) "."))
  (setq p (getpoint "\nPick roughly where you think text is: "))
  (while (not pick)
    (setq pick (nentselp p))
    (if (not pick)(setvar "pickbox" (1+ (getvar "pickbox"))))
  (princ (strcat "\nPICKBOX ended at " (itoa (getvar "pickbox")) ".\n"))
  pick
And, lo, it is true.  Growing the pickbox ended up finding the mtext.
Of course if you are zoomed out it may not have to grow at all.
John F. Uhden
Message 25 of 26
john.uhden
@kpennell and @Sea-Haven,
The pickbox approach applies to (ssget) as well as (nentselp) which means you can add the filter whereas (nentselp) does not accept a filter.
Here.  Try it out for yourself.
(defun c:OnePick ( / *error* vars vals p ss)
   (defun *error* (err)
      (mapcar 'setvar vars vals)
      (vla-endundomark Doc)
      (cond
         ((not err))
         ((wcmatch (strcase err) "*CANCEL*,*QUIT*")
            (vl-exit-with-error "\r                                        ")
         (1 (vl-exit-with-error (strcat "\r*ERROR*: " err)))
      (princ)
   ;; Initialize drawing and program variables:
   (setq Doc (vlax-get (vlax-get-acad-object) 'Activedocument)
         vars '("cmdecho" "pickbox")
         vals (mapcar 'getvar vars)
   (vla-startundomark Doc)
   (setvar "cmdecho" 0)
   (command "_.expert" (getvar "expert")) ;; dummy command
  (while (not ss)
    (setq ss (ssget p '((0 . "*TEXT"))))
    (if (not ss)(setvar "pickbox" (1+ (getvar "pickbox"))))
  (sssetfirst nil ss)
  (*error* nil)
(defun c:OP ()(c:OnePick))
You could rearrange it to be a simple function that takes a point and a filter as arguments...
(defun OnePick (p filter / *error* pb ss)
    (setvar "pickbox" pb)
    (princ)
  (setq pb (getvar "pickbox"))
  (while (not ss)
    (setq ss (ssget p filter))
  (sssetfirst nil ss)
  (*error* nil)
John F. Uhden
Message 26 of 26
Sea-Haven
Nice idea about pickbox so many times get asked find something else near to a point like parallel lines.
