LISP for (mass) Block insert from external DWG
Dear community,
i need a lisp-routine.
This lisp should copy some (nearly 120) blocks from a "static" DWG-file into the current dwg without inserting it into the drawing. the blocks should only copied to the current dwg without user-interaction oder windows for filepath-input.
Cause after i had to change old blocks with the new one (and delete the old ones).
Its the classic requirement: old blocks (think of emergencysymbols) have to change to new design.
Is there an option or anybody can help me?
Thanks in advance!
regards
rs_dev
dennis
I think I am missing something.  So, asking what will clear up what I am missing.  Why not just copy the source 'static' drawing to a new location and rename?
Kent1Cooper
The Design Center [ADC command] has an option [right-click on the Block icon] to redefine a Block with the definition from another drawing without Inserting one, but I don't know of a way to automate that for a whole collection of Blocks.
You may need to make all those Blocks in the "static" drawing into separate drawing files with WBLOCK [there may be routines around here to do that for you], in some dedicated folder, add that folder to your Support File Search Path list, and use a Block-redefinition routine that will bring in the new definitions [there are routines around here to do that, and possibly even to do it automatically for all the drawings in a specified folder -- try some Searching].
Kent Cooper, AIA
