getting a prompt to select objects if there are not objects selected
jagostinho74
jagostinho74
hello,
I have created a new command to delete all the 3DSolids from my drawing but I think that I am getting a prompt to select objects if there are no more 3DSolids to be deleted. How can I prevent this from happening?
My goal is to run the command to delete all 3D Solids and if no 3D Solids can be found just return to the command line.
this is my code
(if (= (getvar "cmdactive") 1) (ssget "x" '((0 . "*3DSOLIDS*"))) (sssetfirst nil (ssget "x" '((0 . "*3DSOLIDS*")))))(command "erase")
and this is what I get in the command line
thank you
Assistant BIM/CAD Manager
Manchester, UK
pbejse
Why not simply
(if (ssget "x" '((0 . "3DSOLID*")(410 . "Model")))
	   (command "Erase" "P" ""))
or
(if (ssget "x" (list '(0 . "3DSOLID*")(Cons 410 (getvar 'ctab))))
 or
(if (setq ss_solids (ssget "x" '((0 . "3DSOLID*"))))
  (foreach e (mapcar 'cadr (ssnamex ss_solids))
    (entdel e)
HTH
marko_ribar
Maybe, something like this :
(if (= (getvar 'cmdactive) 1)
  (ssget "_X" '((0 . "*3DSOLID*")))
  (if (ssget "_X" '((0 . "*3DSOLID*")))
    (vl-cmdf "_.ERASE" "_P" "")
Marko Ribar, d.i.a. (graduated engineer of architecture)
john.uhden
@marko_ribar ,
Somehow I don't think you need the first ssget.
John F. Uhden
Kent1Cooper
The (ssget) filter list entry for entity type is wrong.  No S at the end, and the wildcard asterisks are meaningless -- there aren't any entity types with more letters before or after.
... '((0 . "3DSOLID")) ...
I don't understand the  (if (= (getvar "cmdactive") 1)  part.  Breaking down:
(if (= (getvar "cmdactive") 1); test expression -- is a command [any command] active?
  (ssget "x" '((0 . "*3DSOLIDS*"))); then expression
    ;; looks for them only if another command is active, but does nothing with what it finds
  (sssetfirst nil (ssget "x" '((0 . "*3DSOLIDS*")))); else expression
    ;; selects/highlights/grips any it finds
); if
(command "erase"); thoroughly outside (if) function, and whether or not it found any
That means the Erase command will be called whether or not this is called during another command, and whether or not there are any 3D Solids to find.  But if it's during another command, that won't be an appropriate answer to whatever the current prompt is.
I agree with @pbejse 's simpler suggestions, and offer another, which will remove them from all spaces [whereas the Erase command can "see" only those in the current space]:
(if (setq ss (ssget "_X" '((0 . "3DSOLID"))))
  (repeat (setq n (sslength ss))
    (vla-delete (vlax-ename->vla-object (ssname ss (setq n (1- n)))))
  ); repeat
); if
[I first tried using (entdel), but somehow that didn't remove them from all spaces the way (vla-delete) does.]
Kent Cooper, AIA
jagostinho74
thank you @pbejse .
I'm using your first suggestion.
Manchester, UK
jagostinho74
thank you for such detailed explanation @Kent1Cooper .
It is very useful to understand better what the code is doing.
Manchester, UK
