GETINT and comparison operators
Browning_Zed
Browning_Zed
Hello everyone,
Using the GETINT function, I can set some conditions for entering numbers using the INITGET function, like this:
(initget 6) (getint "input integer: ")
But what if I want to add comparison operators to this combination? For example, the input integer should also be:
(and (/= 1 input_integer) (> 10 input_integer))
How can I do this?
Kent1Cooper
The usual way:  get input in a (while) loop, do the comparison(s), and if unacceptable, go back:
(while
  (and
    (not (initget 6)); no zero, no negative [(not) wrapper because (initget) always returns nil]
    (setq xyz (getint "\nInput positive integer smaller than 10 but not 1: "))
    (or (= xyz 1) (>= xyz 10))
  (prompt "\nNot an acceptable value -- try again.")
or
(while
  (and
    (setq xyz (getint "\nInput positive integer between 2 and 9: "))
    (not (< 1 xyz 10))
Kent Cooper, AIA
Browning_Zed
Thank you for your help.
