Getfolder?
Getfolder?
Message 1 of 12
Getfolder?
Is there a getfiled type of funciton which will allow a user to select a
folder? Maybe something which brings up a dialog similar to the left
side of the Windows Explorer program.
Jeff
Replies (11)
Message 2 of 12
What release of AutoCAD?
If it's A2K, you can use (acet-ui-pickdir), if you can put
up with the lack of a default.
> Thanks,
> Jeff
/* Tony Tanzillo Design Automation Consulting */
/* Programming & Customization for AutoCAD & Compatibles */
/* tony.tanzillo@worldnet.att.net */
/* http://ourworld.compuserve.com/homepages/tonyt */
Message 3 of 12
Jeff,
In the DOSLIB function library (www.mcneel.com), there is the trusty (dos_getdir)
function which allows you to specify a default start point.
Matt
stachoni@bellatlantic.net
>Thanks,
>Jeff
Message 4 of 12
More recent versions of 'acetutil.arx' provide this signature:
* (acet-ui-pickdir [ [ []]])<BR /> Displays a directory selection dialog.<BR /> <MESSAGE> will be displayed in the space above the directory tree<BR /> control.<BR /> <START-DIR> gives the initial directory to be selected.<BR /> <TITLE> will appear as the dialog title.<BR /> Returns a string containing the name of the selected directory, or NIL if<BR /> the dialog was canceled.<BR /> <BR /> I can forward the latest version of 'acetutil.arx' (1.35; check<BR /> '(acet-util-ver)') to anyone who would like an updated copy. It's a 37K .ZIP<BR /> file.<BR /> --<BR /> Frank Whaley<BR /> Autodesk, Inc.<BR /> few@autodesk.com<BR /> http://www.autodesk.com/expresstools<BR /> Express Tools - Your wish is our (command ...)
Message 5 of 12
> file.
Why don't you place it inside a download-area ??
Achim Dabrunz
Message 6 of 12
I second that motion. Unlike other recommendations this solution does not require
the presense of purchased add-ons to run.
Terry
Message 7 of 12
Jeff,
What's wrong with these people?! 🙂
getfiled bit 4 (value 16) says:
16 (bit 4) If this bit is set, or if the default argument ends with a path
delimiter, the argument is interpreted as a path name only. The getfiled
function assumes that there is no default file name. It displays the path in
the Look in: line and leaves the File name box blank.
Would that work?
Message 8 of 12
But don't you have to select a file, not a folder to exit getfiled?
Jeremiah Famer wrote in message
news:7uo15n$f2i8@adesknews2.autodesk.com...
> Jeff,
path
in
> Would that work?
Message 9 of 12
I don't see DOS_GETDIR in DOSLIB14.ARX for R14 (ver 4.0), but it is
available for AK2 in DOSLIB2K.ARX (ver 4.3)
Is there a version of DOSLIB for R14 that has the DOS_GETDIR function. I
wrote my own function a while ago for R14 to get a subdirectory location
when I didn't see anything in DOSLIB to do it.
Mark McDonough
mmcdonough@sasaki.com
Terry W. Dotson wrote in message <380EEC4B.FFE185D5@dotsoft.com>...
(dos_getdir)
require
>Terry
Message 10 of 12
Yes, a new DOSLIB14.ARX, actually up to version 4.4a I think. Check
http://www.mcneel.com and if you don't find it let me know and I'll email it
to you.
Terry
Message 11 of 12
There's nothing wrong with these people, they are striving for perfection and
don't settle for kludge.
Terry
Message 12 of 12
Thanks Terry, I'll revisit the mcneel site and download it.
Mark McDonough
http://www.sasaki.com
news:38103071.DBA068E@dotsoft.com...
it
> to you.
> Terry
