getfiled to select a directory
john.uhden
Mentor Mentor
Message 1 of 15
john.uhden
My ACAD2002 help says if I include flag 16 it will allow me to select a directory, but it doesn't work that way.
Might it work in newer releases so I can avoid having to use dos_getdir?
Don't get me wrong.  I love DOSLIB, but you seem to need a different version installed for almost every AutoCAD release.
John F. Uhden
Replies (14)
Message 2 of 15
Browning_Zed
This works for me:
(getfiled "Select Block" "" "dwg" 16))
Message 3 of 15
john.uhden
@Browning_Zed
Yes, this is about BKEEPER,  but I don't think you're getting it.  Part of the issue is being able to select a directory (folder) not a file.
John F. Uhden
Message 4 of 15
Browning_Zed
*delete*
Message 5 of 15
phanaem
Alternatively to dos_getdir, you can use acet-ui-pickdir which come with ExpressTools
(acet-ui-pickdir [<message> [<start-dir> [<title>]]])
Message 6 of 15
pbejse
What about "Shell.Application"
(setq sh (vla-getInterfaceObject (vlax-get-acad-object) "Shell.Application"))
(setq folder (vlax-invoke sh 'browseforfolder 0 "Browse" "&H10" ))
(vlax-release-object sh)
BIF_RETURNONLYFSDIRS = &H1        ' For finding a folder to start document searching
BIF_DONTGOBELOWDOMAIN = &H2       ' For starting the Find Computer
BIF_STATUSTEXT = &H4              ' Top of the dialog has 2 lines of text for BROWSEINFO.lpszTitle and one line if
	' this flag is set.  Passing the message BFFM_SETSTATUSTEXTA to the hwnd can set the
	' rest of the text.  This is not used with BIF_USENEWUI and BROWSEINFO.lpszTitle gets
	' all three lines of text.
BIF_RETURNFSANCESTORS = &H8
BIF_EDITBOX = &H10                ' Add an editbox to the dialog
BIF_VALIDATE = &H20               ' insist on valid result (or CANCEL)
BIF_NEWDIALOGSTYLE = &H40         ' Use the new dialog layout with the ability to resize
' Caller needs to call OleInitialize() before using this API
BIF_USENEWUI = (BIF_NEWDIALOGSTYLE Or BIF_EDITBOX)
BIF_BROWSEINCLUDEURLS = &H80      ' Allow URLs to be displayed or entered. (Requires BIF_USENEWUI)
BIF_UAHINT = &H100                ' Add a UA hint to the dialog, in place of the edit box. May not be combined with BIF_EDITBOX
BIF_NONEWFOLDERBUTTON = &H200     ' Do not add the "New Folder" button to the dialog.  Only applicable with BIF_NEWDIALOGSTYLE.
BIF_NOTRANSLATETARGETS = &H400    ' don't traverse target as shortcut
BIF_BROWSEFORCOMPUTER = &H1000    ' Browsing for Computers.
BIF_BROWSEFORPRINTER = &H2000     ' Browsing for Printers
BIF_BROWSEINCLUDEFILES = &H4000   ' Browsing for Everything
BIF_SHAREABLE = &H8000            ' sharable resources displayed (remote shares, requires BIF_USENEWUI)
HTH
Message 7 of 15
john.uhden
@pbejse
That's cool, but all I get is a folder object without a name/path property.
Maybe this is a shortcoming of ACAD2002?
John F. Uhden
Message 8 of 15
hak_vz
@john.uhden
Here you can find a script from @Lee_Mac 's that uses "Shell application" to return selected directory.
Use this link for samples and detailed explanation
;; Browse for Folder  -  Lee Mac
;; Displays a dialog prompting the user to select a folder.
;; msg - [str] message to display at top of dialog
;; dir - [str] [optional] root directory (or nil)
;; bit - [int] bit-coded flag specifying dialog display settings
;; Returns: [str] Selected folder filepath, else nil.
(defun LM:browseforfolder ( msg dir bit / err fld pth shl slf )
    (setq err
        (vl-catch-all-apply
            (function
                (lambda ( / app hwd )
                    (if (setq app (vlax-get-acad-object)
                              shl (vla-getinterfaceobject app "shell.application")
                              hwd (vl-catch-all-apply 'vla-get-hwnd (list app))
                              fld (vlax-invoke-method shl 'browseforfolder (if (vl-catch-all-error-p hwd) 0 hwd) msg bit dir)
                        (setq slf (vlax-get-property fld 'self)
                              pth (vlax-get-property slf 'path)
                              pth (vl-string-right-trim "\\" (vl-string-translate "/" "\\" pth))
    (if slf (vlax-release-object slf))
    (if fld (vlax-release-object fld))
    (if shl (vlax-release-object shl))
    (if (vl-catch-all-error-p err)
        (prompt (vl-catch-all-error-message err))
        pth
(LM:browseforfolder "Select folder" nil 0)
Miljenko Hatlak
Message 9 of 15
john.uhden
@hak_vz
It's sort of an abbreviated looking dialog, but it works!
Thanks to you and @Lee_Mac.
I'll have to study why.
John F. Uhden
Message 10 of 15
john.kaulB9QW2
I always used the one from Tony T.
(defun BrowseForFolder ( str / sh folder folderobject result)
    ;; From: Tony Tanzillo
    ;; Newsgroups: autodesk.autocad.customization
    ;; (setq folder (BrowseForFolder "Select Folder"))
    (vl-load-com)
    (setq sh
    (setq folder (vlax-invoke-method sh 'BrowseForFolder 0 str 0))
    (if folder
      (progn
        (setq folderobject (vlax-get-property folder 'Self))
        (setq result (vlax-get-property FolderObject 'Path))
        (vlax-release-object folder)
        (vlax-release-object FolderObject)
        result
another swamper
Message 11 of 15
john.uhden
Thanks, John
That one has a little better flavor.  Tony T. is/was a very wise fellow.
John F. Uhden
Message 12 of 15
john.kaulB9QW2
Not a problem. If anyone finds his orig please post it (I don't think I did but I may have modified it slightly).
another swamper
Message 13 of 15
john.uhden
@john.kaulB9QW2
Modified a Tony T. function?  That's blasphemy!
Although I am still wondering if it's necessary to release local objects.
Do you recall if Tony had done that?
John F. Uhden
Message 14 of 15
john.kaulB9QW2
I think I know what you are referring to (I seem to remember an explanation about when and when not to release objects) but I do not remember.
another swamper
Message 15 of 15
john.uhden
@john.kaulB9QW2
Do you seem to remember this?
JohnK
  • Administrator
  • Seagull
(vlax-release-object obj) vs (setq obj nil)
« Reply #5 on: August 02, 2004, 04:48:33 PM »
*Sigh*
Answer: Release at the end of your loop.
John F. Uhden
