Get Vertices
Get Vertices
adaptacad
Message 1 of 10
Get Vertices
adaptacad
Hello again everyone.
Do any of you have a command that inserts the angle on the polyline vertices ??
Something like:
I believe this has been answered before but I didn't find it in my surveys.
Replies (9)
Message 2 of 10
Kent1Cooper
Does something like >this< do what you want?  It's just the first result I got from putting "Dimension Polyline Angles" into the Search window, but there are many others.
Kent Cooper, AIA
Message 3 of 10
adaptacad
hello @Kent1Cooper  I saw this post but it doesn't process with open polylines, it takes a long time and doesn't finish. and in closed polylines he places the dimensions and there is no need
Message 4 of 10
Kent1Cooper
I wasn't advocating for a specific one [and didn't try that one], but mostly indicating that there a lot of routines already out there.  Maybe you've already looked at all those found by my Search wording, but other wordings may find more.
Kent Cooper, AIA
Message 5 of 10
hak_vz
@adaptacad  Try this. Not fully tested but I hope it will work for you.
(defun c:dim_poly_segment_angles ( /
	LM:intersections take take2 pick_poly adoc e plo coords
	cir co intlist pt p1 p2 p3 arcent ao side
	;Author:  hak_vz
	;Friday, November 19, 2021
	;https://forums.autodesk.com/t5/user/viewprofilepage/user-id/5530556
	;Posted at
	;https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/get-vertices/td-p/10766795
	;Creates angular dimensions between polyline segments
	(defun *error* ( msg )
		(if (not (member msg '("Function cancelled" "quit / exit abort")))
			(princ)
		(if (and adoc) (vla-endundomark adoc))
		(setvar 'cmdecho 0)
		(princ)
	(defun LM:intersections ( ob1 ob2 mod / lst rtn )
		(if (and (vlax-method-applicable-p ob1 'intersectwith)
				 (vlax-method-applicable-p ob2 'intersectwith)
				 (setq lst (vlax-invoke ob1 'intersectwith ob2 mod))
			(repeat (/ (length lst) 3)
				(setq rtn (cons (list (car lst) (cadr lst) (caddr lst)) rtn)
					  lst (cdddr lst)
		(reverse rtn)
	(defun take (amount lst / ret)(repeat amount (setq ret (cons (car lst) (take (1- amount) (cdr lst))))))
	(defun take2 (lst) (take 2 lst))
	(defun pointlist2d (lst / ret) (while lst (setq	ret (cons (take 2 lst) ret) lst (cddr lst))) (reverse ret))
	(defun pick_poly ( / e eo)
		(setq e (car(entsel "\n\nSelect polyline >")))
		(cond
			((and (not e) (= (getvar 'Errno) 7))
			(princ "\nNothing selected. Try again!")
			(pick_poly))
			((and e (not (= (vla-get-ObjectName (vlax-ename->vla-object e)) "AcDbPolyline")))
			  (princ "\nSelected entity is not a polyline!")
			  (pick_poly)
			((and e (= (vla-get-ObjectName (vlax-ename->vla-object e)) "AcDbPolyline"))
				e
(setq adoc (vla-get-ActiveDocument (vlax-get-acad-object)) blocks (vla-get-blocks adoc))
(setq e (pick_poly) plo (vlax-ename->vla-object e))
(setq coords (pointlist2d(vlax-get plo 'Coordinates)))
(if (= (vlax-get plo 'Closed) 0)
	(setq coords (cdr(take (1- (length coords))coords)))
	(setq coords (append coords (list (cadr coords))))
(if (null radius)(setq radius (getreal "\nEnter arc dimension internal radius > ")))
(if (null radius)(setq radius 50))
(initget "L R")
(setq side(getkword "\nSelect side left or right <L R> >> "))
(vla-startundomark adoc)
(setvar 'cmdecho 0)
(foreach pt coords
	(setq cir(entmakex (list (cons 0 "CIRCLE") (cons 10 pt) (cons 40 radius))))
	(setq co (vlax-ename->vla-object cir))
	(setq intlist (mapcar 'take2 (LM:intersections co plo acextendboth)))
	(mapcar 'set '(p1 p2) (vl-sort intlist '(lambda (x y) (> (vlax-curve-getdistatpoint plo x)(vlax-curve-getdistatpoint plo y)))))
	(command "_.arc" "c" pt p1 p2)
	(setq arcent (entlast) ao (vlax-ename->vla-object arcent))
    (setq p3 (vlax-curve-getpointatdist ao(* 0.5(vlax-get ao 'ArcLength))))
	(if (= side "R")(setq p3 (polar p3 (angle P3 PT)(* 2.0 radius))))
	(vlax-release-object co)
	(vlax-release-object ao)
	(entdel cir)
	(entdel arcent)
	(command "_.dimangular" "" "_none" pt "_none" p1 "_none" p2 "_none" p3)
(setvar 'cmdecho 1)
(princ "\Done!")
(princ)
Miljenko Hatlak
Message 6 of 10
adaptacad
@hak_vz You are a legend!! Thank you very much.
Message 7 of 10
adaptacad
@hak_vz
One last question, why not process when the polyline has many vertices ??
Message 8 of 10
hak_vz
I just noticed this error, but will check it out tomorrow.
Miljenko Hatlak
Message 9 of 10
adaptacad
@hak_vz Thank you very much in advance.
Message 10 of 10
hak_vz
It should now work OK
	cir co intlist pt p1 p2 p3 arcent ao side radius
	;Author:  hak_vz
	;Friday, November 26, 2021
	;Posted at
			(princ)
		(setvar 'cmdecho 0)
		(princ)
					  lst (cdddr lst)
		(reverse rtn)
		(cond
			(pick_poly)
			((and e)
			 (setq eo (vlax-ename->vla-object e))
			  (cond
				((not (= (vlax-get eo 'ObjectName) "AcDbPolyline"))
					(pick_poly)
				(T e)
	(setq adoc (vla-get-ActiveDocument (vlax-get-acad-object)))
	(setq plo (vlax-ename->vla-object (pick_poly)))
	(setq coords (vlax-get plo 'Coordinates))
	(if (and coords)
		(progn
			(setq n (-(length coords)1))
			(setq coords (cdr(reverse(cdr(reverse coords)))))
			(if (null radius)(setq radius 20))
			(initget "L R")
			(setvar 'cmdecho 0)
			(foreach pt coords
			(setq intlist (mapcar 'take2 (LM:intersections co plo acextendnone)))
			(entdel cir)
			(entdel arcent)
			(setvar 'cmdecho 1)
			(princ "\Done!")
 (princ)
Miljenko Hatlak
