ADD OPTION SELECTION TO MY LISP ROUTINE
venturini.anthony
Message 1 of 16
venturini.anthony
im trying to create a lisp routine to edit layer transparency. how would i add a prefix to this code to run different options. for instance if the command is run it will give you an option to pick a,b or c. if a is picked then the following code is run, if b is picked, a different variation of the code is run. the current code below works for the layers, but id like to add the selection feature.
(vl-load-com)
(defun c:fade (/ *error* c_doc c_lyrs)
; localised error function
(defun *error* ( msg )
(if (and c_doc (= 8 (logand 8 (getvar 'UNDOCTL)))) (vla-endundomark c_doc))
(if (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")) (princ (strcat "\nOops an Error : " msg " occurred.")))
(princ)
);_end_*error*_defun
;initial setups go here
(setq c_doc (vla-get-ActiveDocument (vlax-get-acad-object))
c_lyrs (vla-get-layers c_doc)
);end_setq
;start of altering drawing
(vla-startundomark c_doc)
(vlax-for lyr c_lyrs
(if (or (wcmatch (vla-get-name lyr) "*|*" ) (wcmatch (vla-get-name lyr) "XR-*" ))
(progn
(command "-LAYER" "_TR" 60 (vla-get-name lyr) "")
);end_progn
);end_if
(if (or (wcmatch (vla-get-name lyr) "XR-BASE|B-PROPERTY" ) (wcmatch (vla-get-name lyr) "XR-BASE|B-NONPROPERTY" ) (wcmatch (vla-get-name lyr) "XR-BASE|B-PROPERTY-STREET-TEXT" ) (wcmatch (vla-get-name lyr) "XR-TITLE|*" ))
(progn
(command "-LAYER" "_TR" 0 (vla-get-name lyr) "")
);end_progn
);end_if
);end-for
(princ)
);end_defun
Replies (15)
Message 2 of 16
john.uhden
@venturini.anthony
I would probably subdivide the program into localized subfunctions...
(defun c:Topping ( / ans do_A do_B do_C)
(defun do_A ...)
(defun do_B ...)
(defun @do_C ...)
;; then use getkword...
(initget "Mushrooms "Peppers Sausage")
(setq ans (getkword "\nSelect a topping <Mushrooms>/Peppers/Sausage: "))
(cond
  ((or (not ans)(= ans "Mushrooms"))(@do_A))
  ((= ans "Peppers")(do_B))
  ((= ans "Sausage")(do_C))
;; Notice we made Mushrooms the default ('cause that what my wife likes).
;; And the user doesn't have to type in "Sausage" because we capitalized the first letters, so a simple "S" (upper or lower case) will suffice.
John F. Uhden
Message 3 of 16
Kent1Cooper
As an aside, be aware that you can assign options to more than one Layer at a time, in comma-separated format including wildcards, and do more than one option within a single Layer command.  You should be able to replace your entire (vlax-for ...  function with just:
(command "_.layer"
  "_tr" 60 "*|*,XR-*"
  "_tr" 0 "XR-BASE|B-PROPERTY,XR-BASE|B-NONPROPERTY,XR-BASE|B-PROPERTY-STREET-TEXT,XR-TITLE|*"
But more directly to your question, I agree with @john.uhden that the (initget)/(getkword) approach is the way to go.  [But his needs some fixing of variable names, some of which have @ prefix in one place but not another.]
Kent Cooper, AIA
Message 4 of 16
Kent1Cooper
I suggest doing that line this way:
(setq ans (getkword "\nSelect a topping [Mushrooms/Peppers/Sausage] <Mushrooms>: "))
Putting the options in square brackets with slash-separators will, in use, show the prompt with the initial capitals bold and blue:
just as with regular AutoCAD command options, and you can pick one on-screen or use the pull-down approach if you prefer either to typing in an option [which you can still do].
Kent Cooper, AIA
Message 5 of 16
john.uhden
@Kent1Cooper
Thank you for pointing out the @ confusion.
I happen to prefix all my subfunctions with @ and I started with that style
but decided I might confuse the lurkers, so I went to remove it but was
obviously sloppy.
John F. Uhden
Message 6 of 16
john.uhden
Thank you again, @Kent1Cooper. Excellent suggestion.
My brain gets stuck in the 1990s, so I often fail to take advantage of more
modern features.
John F. Uhden
Message 7 of 16
venturini.anthony
thanks, i think that will help on the timing problem that im having. when i replaced it, i get this message that pops up, and then nothing happens, how can i fix this?
and heres the code now for reference
(vl-load-com)
(princ)
);end_setq
(command "_.layer"
"_tr" 60 "*|*,XR-*"
(princ)
);end_defun
Message 8 of 16
Kent1Cooper
You're still in the Layer command, because you didn't include the "" Enter to finish it:
(command "_.layer"
  "_tr" 60 "*|*,XR-*"
Kent Cooper, AIA
Message 9 of 16
venturini.anthony
that fixed that issue, but i get this message in the command line, but it end there and nothing happens
Message 10 of 16
Sea-Haven
Out of the 1990's
(if (not AH:Butts)(load "Multi Radio buttons.lsp"))
(setq ans (ah:butts 1 "v"  '("Select a topping" "Mushrooms" "Peppers" "Sausage")))
I think it was Grrr or RLX had a dynode version of same task so would appear on screen as a choice.
Message 11 of 16
Kent1Cooper
The operational parts of your code [in two posts] end with Layer operations.  What else is supposed to happen?
Kent Cooper, AIA
Message 12 of 16
tinouye42
Hi, I'm trying to expand on this code but am getting a "no function definition" error. Can someone take a look at let me know what's wrong with my code? Thanks!
Message 13 of 16
ec-cad
Modified your code, basically, removed the C: from your subfuncions.
With a C: prefix, they become something you can call from the Command prompt.
Without the C: prefix they are just another function of the overall function.
ECCAD
(defun c:Topping ( / ans mush pepp saus)
(defun mush ()
  (princ "\nYou chose mushrooms")
(defun pepp ()
  (princ "\nYou chose peppers")
(defun saus ()
  (princ "\nYou chose sausage")
(princ "\nFunctions loaded")
(initget "Mushrooms Peppers Sausage")
(cond
  ((or (not ans)(= ans "Mushrooms"))(mush)); removed the c:
  ((= ans "Peppers")(pepp)) ; removed the c:
  ((= ans "Sausage")(saus)); removed the c:
Message 14 of 16
tinouye42
Got it. Thanks for explaining!
Message 15 of 16
Kent1Cooper
Any time there is repetition of something multiple times, such as the "\nYou chose" portion of the prompts in all those sub-routines, and the fact that all those prompts are defined separately, there's probably a way to do it that contains that repetitive part only once.  And it often means you can eliminate some variables and or sub-routines, as is true in this case:
(defun c:Topping (/ ans)
  (prompt (strcat "\nYou chose " (cond (ans) ("Mushrooms")) "."))
Kent Cooper, AIA
Message 16 of 16
Sea-Haven
Look at message 10 did not post the Multi radio buttons.lsp supports up to about 20+ buttons.
