Get the Order Number of Parameters in Dynamic Blocks
Julio_Soto
Advisor Advisor
Julio_Soto
I found a LISP here to rearrange the display order of parameters in dynamic blocks. Most importantly this can also re-order Lookup Parameters. The problem comes if someone used the Parameters Manager tool palette to re-order the parameters. If you used the tool palette then the LISP cannot reorder them with the LISP. They will follow whatever Order is shown in the palette.
Is it possible to get this "Order" value and reset it to nil?
Sea-Haven
Just a question why worry about order, if you have made the block you know order. The same is with normal block attributes you can edit a value by order rather than using a tag name a method I have used but hardly ever used, is it worth the effort. For the odd occasion get a pencil/paper write down parameter name in order and code.
Julio_Soto
if it was my own block I wouldn't care as much. this block will be part of the company standard. And having parameters out of order does not look professional.
Sea-Haven
Understand now nothing to do with coding to change parameters. Yes have done to block attributes so they follow a sequence of enter data rather than jumping all over the place as creator has not taken time to look at what they created v's user input.
