Get Table Cell Text without formatting
Perhaps I'm overlooking things somewhere but I can't find enough information to resolve this issue.
Background: I have PASTESPEC an AutoCAD Entity table into AutoCAD after copying it from excel.
I am testing code to confirm the Headers of the table, however I cannot find a way to return the EXACT Cell Text as a string. Can somebody critique my code please?! Thank you
(defun c:EZGEOMARKER (/ GeoTable LatCell)
;;;;;Load the extended AutoLISP functions related to ActiveX support
(vl-load-com)
;;;;;Select table with data for GeoMarkers
(setq GeoTable (entsel "\n(EZGEOMARKER) Please select AutoCAD Table with Latitude/Longitude/Note: "))
;;;;;Set variables which will be tested later
(setq LatCell (vla-gettext (vlax-ename->vla-object (car GeoTable)) 0 0))
(alert LatCell)
);defun
devitg
The text it is a MTEXT, with it's format. You need to UNFORMAT it.
Thank you for the response. I was thinking it might be so. How might I approach that with LISP in this routine? Is that possible with LISP?
~D
devitg
devitg,
Your link was useful and ultimately led me to the following..
https://cadabyss.wordpress.com/2010/01/04/stripmtext-v5-0/
Very awesome of them to distribute this. Such a large amount of coding work! I have chosen to incorporate their function into my LISP so that the table will be stripped after being chosen. Wish it could be easier. Thanks again
~D
devitg
John Uhden  is an often and daily colaborator .
