Get Region Boundary
Get Region Boundary
Ysuuny
Get Region Boundary
Ysuuny
Hello!!
I'm developing it with civil3d c# and it's not solved, so I'm leaving a post.
I only want to bring the outer line (polyline) from the region with a hole in the middle
- I explode the region, but it's hard to join because it's remain to the middle line
- I've also checked if it's in the area based on the point criteria, but it's not working well
I also referred to this library(GeometryExtensionsR19, brep) and worked hard...
Please help me,, 😉
Joe-Bouza
LINEWORKSHRINKWRAP ?
Joe Bouza
paullimapa
Manually this is how I let AutoCAD create the new inner & outer PLINEs from the REGION
Enter command:
BPOLY
In the Boundary Creation dialog under Boundary set click New and select the Region and hit Enter:
The Boundary Creation dialog re-appears and this time click on Pick Points but this time select the space that makes up the REGION:
If successful AutoCAD will show selected the new PLINE boundaries generated:
Hit Enter to complete the command.
Now you've got the PLINEs automatically generated for you:
Paul Li
IT Specialist
@The Office
paullimapa
Also this is how I would do it with lisp code:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/how-to-use-bpoly-function/m-p/127731...
;;;--- aec_setmrk is used w/ (aec_getmrk) it sets pt. marker
(defun aec_setmrk ()
  (command "_.Point" "@")
  (setq aec_pt-mrk (entlast))
  (entdel aec_pt-mrk)
  (princ)
) ;defun
;;;--- aec_getmrk starts at aec_pt-mrk (aec_setmrk) retrieves to current entity
(defun aec_getmrk (/ aec_ss)
	(if aec_pt-mrk
		(progn
			(setq aec_ss (ssadd))
			(while (setq aec_pt-mrk (entnext aec_pt-mrk))
				(ssadd aec_pt-mrk aec_ss)
      (setq aec_pt nil)
			aec_ss
	) ;if
) ;defun
(if (setq bp (getpoint "\nSelect Internal Point: ")) ; select point in middle of REGION
 (progn
  (aec_setmrk) ; set beginning marker
  (command "._-Boundary" "_non" bp "") ; create boundaries
  (if (setq ss (aec_getmrk))(sssetfirst nil ss)) ; highlight them
) ; if
Paul Li
IT Specialist
@The Office
