Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Get Region Boundary
Get Region Boundary
Ysuuny
Get Region Boundary
Ysuuny
Hello!!
I'm developing it with civil3d c# and it's not solved, so I'm leaving a post.
I only want to bring the outer line (polyline) from the region with a hole in the middle
- I explode the region, but it's hard to join because it's remain to the middle line
- I've also checked if it's in the area based on the point criteria, but it's not working well
I also referred to this library(GeometryExtensionsR19, brep) and worked hard...
Please help me,, 😉
Joe-Bouza
LINEWORKSHRINKWRAP ?
Joe Bouza
paullimapa
Manually this is how I let AutoCAD create the new inner & outer PLINEs from the REGION
Enter command:
BPOLY
In the Boundary Creation dialog under Boundary set click New and select the Region and hit Enter:
The Boundary Creation dialog re-appears and this time click on Pick Points but this time select the space that makes up the REGION:
If successful AutoCAD will show selected the new PLINE boundaries generated:
Hit Enter to complete the command.
Now you've got the PLINEs automatically generated for you:
Paul Li
IT Specialist
@The Office
paullimapa
Also this is how I would do it with lisp code:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/how-to-use-bpoly-function/m-p/127731...
;;;--- aec_setmrk is used w/ (aec_getmrk) it sets pt. marker
(defun aec_setmrk ()
  (command "_.Point" "@")
  (setq aec_pt-mrk (entlast))
  (entdel aec_pt-mrk)
  (princ)
) ;defun
;;;--- aec_getmrk starts at aec_pt-mrk (aec_setmrk) retrieves to current entity
(defun aec_getmrk (/ aec_ss)
	(if aec_pt-mrk
		(progn
			(setq aec_ss (ssadd))
			(while (setq aec_pt-mrk (entnext aec_pt-mrk))
				(ssadd aec_pt-mrk aec_ss)
      (setq aec_pt nil)
			aec_ss
	) ;if
) ;defun
(if (setq bp (getpoint "\nSelect Internal Point: ")) ; select point in middle of REGION
 (progn
  (aec_setmrk) ; set beginning marker
  (command "._-Boundary" "_non" bp "") ; create boundaries
  (if (setq ss (aec_getmrk))(sssetfirst nil ss)) ; highlight them
) ; if
Paul Li
IT Specialist
@The Office
