Get Rectangle Center Point
Message 1 of 12
Hello, I need a function which "finds the center point of a rectangle" and also, store distance from center to width in a variable and distance from center to length in another variable.  Thanks!
Accepted solutions (3)
Replies (11)
Message 2 of 12
ВeekeeCZ
A rectangle from a polyline? Or lines? Better post a dwg example.
And which would be the width and which length? Just general w<l?
Message 3 of 12
A Polyline rectangle. Any width and length.
I want to draw a circle with its center as rectangle center with below function. But circle radius shouldn't go outside rectangle. So I want to use distances from sides to limit radius size (if that's the right approach)!
(defun C:DRWCRC ()
  	(initget 1)
	(setq c (getpoint "\nChoose Center:"))
	(initget 7)
	(setq rad (getdist c "\nRadius Size:"))
	(command "circle" c rad)
        (princ)
Message 4 of 12
ВeekeeCZ
Sure. Your func is not bad.. but this one is a bit better - less dependent on environment settings.
(vl-load-com)
(defun c:CircleInscribed ( / s e p d r)
  (if (setq s (ssget '((0 . "LWPOLYLINE"))))
    (repeat (setq i (sslength s))
      (setq e (ssname s (setq i (1- i))))
      (setq p (mapcar '/ (mapcar '+ (vlax-curve-getpointatparam e 0) (vlax-curve-getpointatparam e 2)) '(2 2)))
      (setq r (min (setq d (vlax-curve-getdistatparam e 1)) (- (vlax-curve-getdistatparam e 2) d)))
      (entmakex (list (cons 0 "CIRCLE") (cons 10 p) (cons 40 (/ r 2))))))
  (princ)
If your rectangle is from 4 vertices (if else the routine fails), then parameter 0 is the first one, and +1 next one.
Message 5 of 12
Kent1Cooper
If you can count on always selecting an actually rectangular Polyline, and want the largest internal Circle drawn, something like this? [untested]:
(vl-load-com); in case needed
(defun C:CMR ; = Circle at Midpoint of Rectangle
  (/ rec)
  (setq
    rec (car (entsel "\nRectangle to draw Circle in the middle of: "))
    dim1 (/ (distance (vlax-curve-getStartPoint rec) (vlax-curve-getPointAtParam rec 1)) 2)
    dim2 (/ (distance (vlax-curve-getPointAtParam rec 1) (vlax-curve-getPointAtParam rec 2)) 2)
  ); setq
  (command "_.circle"
    "_non"
    (mapcar '/
      (mapcar '+ (vlax-curve-getStartPoint rec) (vlax-curve-getPointAtParam rec 2))
      '(2 2 2)
    ); mapcar /
    (min dim1 dim2); radius
  ); command
  (princ)
); defun
That leaves the distances you want in the 'dim1' and 'dim2' variables.
It could be made to verify that you selected a Polyline, that it's closed and with 4 vertices, and even check whether it's rectangular (I have code for that if you want).
Kent Cooper, AIA
Message 6 of 12
This is really good, Thanks! But I want to be able to draw it MAX (to the sides of rectangle) MIN (any size smaller)!
Message 7 of 12
Thanks! Same here, I want to be able to draw it MAX (to the sides of rectangle) MIN (any size smaller)!
Message 8 of 12
ВeekeeCZ
One routine for min and second for max?
... if yes, then find a MIN function and change it to MAX. As simple as that.
Message 9 of 12
Kent1Cooper
@Anonymous wrote:
.... I want to be able to draw it MAX (to the sides of rectangle) MIN (any size smaller)!
This should [untested] offer the MAXimum size that fits within the rectangle as the default, and accept any other size input from the User:
  (/ rec rad)
  (setq
  ); setq
  (initget 6); no zero, no negative
  (setq rad
    (cond
      ( (getdist
          (strcat
            "\nRadius of Circle <max. "
            (rtos (min dim1 dim2)); in current Units mode/precision
          ); strcat
        ); getdist
      ); User-input condition
      ((min dim1 dim2)); default on User Enter
    ); cond
  ); setq
  (command "_.circle"
    "_non"
    (mapcar '/
      '(2 2 2)
    ); mapcar /
    rad ; radius
  ); command
  (princ)
); defun
It could be made to reject sizes larger than what fits in the rectangle, if that's needed.
Kent Cooper, AIA
Message 10 of 12
This is Perfect. Toast! 🍻😀
Message 11 of 12
hak_vz
(defun circle_in_rect ( min_max / *error* adoc take take2 e eo eco coords a b c d1 d2 m p q)
	(defun *error* ( msg )
			(if (not (member msg '("Function cancelled" "quit / exit abort")))
				(princ (strcat "\nError: " msg))
			(setvar 'cmdecho 1)
			(princ)
	(defun take (amount lst / ret) (repeat amount (setq ret (cons (car lst) (take (1- amount) (cdr lst))))))
	(defun take2 (lst) (take 2 lst))
	(setq adoc (vla-get-activedocument (vlax-get-acad-object)))
	(vla-endundomark adoc)
	(vla-startundomark adoc)
	(setvar 'cmdecho 0)
		(while (setq e (car(entsel "\nSelect rectangle >")))
			(setq eo (vlax-ename->vla-object e) co(vlax-get eo 'Coordinates))
			(while co (setq coords (cons (take2 co) coords) co (cddr co)))
				(setq
					a (car coords)
					b (cadr coords)
					c (caddr coords)
					p (mapcar '*(mapcar '+ a b) '(0.5 0.5))
					q (mapcar '*(mapcar '+ b c) '(0.5 0.5))
					m (mapcar '*(mapcar '+ a c) '(0.5 0.5))
					d1 (distance m p)
					d2 (distance m q)
				(if(eq min_max "<")
					(command "_.circle" "_non" m (car(vl-sort (list d1 d2) '<)))
					(command "_.circle" "_non" m (car(vl-sort (list d1 d2) '>)))
	(setvar 'cmdecho 1)
	(princ)
(defun c:min_circle_in_rect nil (circle_in_rect "<"))
(defun c:max_circle_in_rect nil (circle_in_rect ">"))
(defun min_circle_in_rect nil (circle_in_rect "<"))
(defun max_circle_in_rect nil (circle_in_rect ">"))
Miljenko Hatlak
Message 12 of 12
Sea-Haven
Nice idea 4 options, for me add a overall (defun c:cinr then use a cond on pick. Need multi radio buttons.lsp. The button picked can be saved so next run just click OK.
