(defun c:buffer ( / ss bw i lst e eo p1 p2 ang1 ang2 ang3 ang4 pa pb a b c d lst ssreg)
(setq bw (getreal "\nOffest distance from line >"))
(princ "\nSelect line enitities >")
(setvar 'cmdecho 0)
(setq ss (ssget '((0 . "LINE"))) i -1 ssreg (ssadd))
(while (< (setq i (1+ i)) (sslength ss))
(setq
e (ssname ss i)
eo (vlax-ename->vla-object e)
p1 (vlax-get eo 'Startpoint)
p2 (vlax-get eo 'Endpoint)
ang1 (angle p1 p2)
ang2 (angle p2 p1)
ang3 (+ ang1 (/ pi 2))
ang4 (- ang1 (/ pi 2))
pa (polar p1 ang1 (+ (distance p1 p2) bw))
pb (polar p2 ang2 (+ (distance p2 p1) bw))
a (polar pa ang3 bw)
b (polar pb ang3 bw)
c (polar pb ang4 bw)
d (polar pa ang4 bw)
(command "_.pline" "_non" a "_non" b "_non" c "_non" d "c")
(command "_region" (entlast) "")
(setq ssreg (ssadd (entlast) ssreg ))
(command "_.union" ssreg "")
(setq ssreg nil lst (entlast))
(command "_explode" (entlast))
(while (setq lst (entnext lst))
(setq ssreg (ssadd lst ssreg ))
(command "_.pedit" "m" ssreg "" "y" "j" "" "" "")
(setvar 'cmdecho 1)
(princ)
Try this. For a simplicity code works only with line objects.
Select as a solution if it works for you. Further changes possible.
Miljenko Hatlak
