Get part off filename (list)
djurk_haas
djurk_haas
I can't figger out why my code below gives: error: bad argument type: consp "" instead of "B"
(setq str (strcat (substr (getvar 'dwgname) 1 (vl-string-search ".dwg" (getvar 'dwgname))) " "))
 (while (/= str "")
    (setq
      sub (substr str 1 (setq i (vl-string-search " " str)))
      ret (cons sub ret)
     str (substr str (+ i 2))
 (reverse ret)
;returns ("RV" "CZE" "B" "W0100" "P")
(setq e (nth 3 str))
Thanks in advance!
dlanorh
 (while (/= str "")
    (setq
      ret (cons sub ret)
 (reverse ret)
Thanks in advance!
str is a string not a list. nth works on lists and if str were a list as in ("RV" "CZE" "B" "W0100" "P") (nth 3 lst) would return "W0100" as lists are 0 (zero) based
try (setq e (nth 2 (reverse ret)))
I am not one of the robots you're looking for
ВeekeeCZ
You should use (setq e (nth 3 ret)))
djurk_haas
Thanks that does the trick!!
One more thing:
(setq e (nth 0 ret)) returns "P" instead of "CZE"?
ВeekeeCZ
See the code.
You reversed (reverse red) but did not save it!? Unless it's a result of your sub, you need to save it (setq ret (reverse ret))
Then, CZE is 2nd item in the list, so the index should be 1 (since 0 is for the first one).
