AutoCAD lisp to insert dimensions value to excel sheet or table
Message 1 of 15
Hi I am new on this forum
can any body help me for a lisp which can do a routine work for me,
A lisp which can automatically take data of dimensions value and put in excel sheet or table in same file, ( number , length, width )
I am in marble industry where I have to take thousand of dimensions for marble cutting on daily basis which is so much time costing and hard work
i would appreciate for any help
Replies (14)
Message 2 of 15
devitg
You can try with DATAEXTRACTION .
Would you , please , upload a sample.dw
Message 3 of 15
Thanks for your reply
I have already tried to export dimensions data by DATAEXTRACTION  but unable to do so, in data extraction it showS only number of dimensions not values,
I need some thing like this as in screen shot I have 3 pcs with number and dimensions, need lisp to put data in table as shown
Message 4 of 15
Sea-Haven
Did you Google pretty sure this exact request has been answered before.
Message 5 of 15
Thanks for your kind reply,
I have googled but didn’t find any solution for this, if some one write a LISP for me i will be thank full to him, because I don’t know much about writing lisp,
Message 6 of 15
Sea-Haven
Ok a quick method comes to mind one pick are the shapes numbered already or do you want that added also ?
If one edge is always horizontal very quick to do. Come to think about it do you want the dims added as well ? Just draw the shape, even that can be automated further as they are basic shapes.
Please post a sample dwg for dim style and table style with shapes.
Message 7 of 15
Sea-Haven
Threw this together, code required
(if (not AH:getvalsimg)(load "Multi Getvals img.lsp"))
(setq ans (AH:getvalsimg "D:\\Acadtemp\\Shapes" 40 (list "Enter values" "Shape number" 5 4 "1" "Enter width" 5 4 "900" "Enter Ht" 5 4 "1000" "Enter L off" 5 4 "300" "Enter R offset" 5 4 "300")))
Message 8 of 15
Shapes are numbered already and yes one edge is horizontal always ,
Message 9 of 15
Sea-Haven
You can try this, have 2 choices a new table or add to an existing table it will add table rows as you pick.
It can be very much automated but this is a start and the free version. Need your dwg to check table. I would consider the drawing shapes can do much faster.
You must save the multi radio buttons.lsp to your lisp support path or it will not be found that's the dcl.
; Make a table of shapes based on bounding box.
; By Alan H march 2020 info@alanh.com.au
(defun c:dimtab ( / dolabel dotext enddimtab AH:maketable objtable obj1 obj2 tsr len ht)
(defun enddimtab ()
(alert "Object is not a pline, please join and do again")
(exit)
; now do table
(defun AH:maketable ( / pt1 numrows numcolumns rowheight colwidth )
(setvar 'ctab "Model")
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(setq curspace (vla-get-modelspace doc))
(setq pt1 (vlax-3d-point (getpoint "\nPick point for top left hand of table:  ")))
(setq numrows 3)
(setq numcolumns 3)
(setq rowheight 0.3)
(setq colwidth 1.8)
(setq objtable (vla-addtable curspace pt1 numrows numcolumns rowheight colwidth))
(vla-settext objtable 0 0 "Dimension table")
(vla-settext objtable 1 0 "Number")
(vla-settext objtable 1 1 "Width")
(vla-settext objtable 1 2 "Length")
(setq objtable (vlax-ename->vla-object (entlast)))
) ; defun
(defun AH:addlinet ( / rowcnt rowhgt)
(setq rowcnt (vla-get-rows objtable))
(setq rowhgt (vla-getRowHeight objtable 2))
(vla-InsertRows objTable rowcnt rowhgt 1)
(vla-settext objtable (- rowcnt 1) 0 tsr)
(vla-settext objtable (- rowcnt 1) 1 len)
(vla-settext objtable (- rowcnt 1) 2 ht)
(if (not AH:Butts)(load "Multi Radio buttons.lsp"))
(if (= but nil)(setq but 1))
(setq ans (ah:butts but "h"  '("Table " "Make New " "Use existing ")))
(if (= but 1)
(AH:maketable)
(setq objtable (vlax-ename->vla-object (car (entsel "pick existing table"))))
(while (setq ent (entsel "Pick text "))
(setq obj1 (vlax-ename->vla-object (car ent)))
(setq tsr (vlax-get Obj1 'Textstring))
(setq obj2 (vlax-ename->vla-object (car (entsel "Pick pline object "))))
(if (= (vla-get-objectname obj2) "AcDbPolyline")
(progn
(vla-GetBoundingBox obj2 'minpoint 'maxpoint)
(setq pointmin (vlax-safearray->list minpoint))
(setq pointmax (vlax-safearray->list maxpoint))
(setq len (rtos (abs (- (car pointmin)(car pointmax))) 2 3))
(setq Ht (rtos (abs (- (cadr pointmin)(cadr pointmax))) 2 3))
(AH:addlinet)
(enddimtab)
Message 10 of 15
devitg
Would you , please , upload such sample.dwg
Message 11 of 15
devitg
Please, find attached , dwg lsp and csv
Message 12 of 15
I am out of office in morning I will add sample drawing 👍
Message 13 of 15
Sea-Haven
Did you try what I posted I did test it.
Message 14 of 15
thanks a lot that do some work for me although it saves data in notepad but ok i can easily copy it to excel sheet instead of typing each dimension again and again
thanks a lot bro
Message 15 of 15
i tried but this code not working for me
