Get attribute values
Hello all, I was trying to extract an attribute value from a block, I used this function by Lee Mac, but for some reasons it is not working properly for me.
Here is the function
(defun LM:getattributevalue ( blk tag / enx )
     (if (= "ATTRIB" (cdr (assoc 0 (setq enx (entget (setq blk (entnext blk)))))))
        (if (= (strcase tag) (strcase (cdr (assoc 2 enx))))
            (cdr (assoc 1 enx))
and Here is part of my code, I have a block with an attribute tag "DIMENSION"
(setq obj (car (entsel)) )
(setq str (LM:GetAttributeValue obj "DIMENSION" ))
;; I have three attributes in the block, it works with the first attribute tag, but it is not working with the rest of them
I appreciate any help, thanks in advance
Solomon Tessema
Never mind I got another function by Lee Mac, the iterative one,that works great.
http://www.lee-mac.com/attributefunctions.html#algetattributevalueit
Thank you all
Ali_Amine
Hello there :- )
I am trying to use the lisp (attributefunctions), but I can not find the command to run it 😞
Any help ?
Thank you !
Kent1Cooper
@Ali_Amine wrote:
.... I am trying to use the lisp (attributefunctions), but I can not find the command to run it .....
There is no command.  It defines a collection of functions that take arguments.  The header information at each function describes what arguments need to be supplied.   You use them in parentheses, starting with the function name and followed by the necessary argument(s).  For example, to use the first one, when you want to get the value of the Attribute with the Tag "MouseName" in an insertion of a Block called "DisneyCharacters", the usage would look like this:
(LM:vl-getattributevalue "DisneyCharacters" "MouseName")
which should presumably return either "Mickey" or "Minnie".
Kent Cooper, AIA
Ali_Amine
Thank you  !
