I've been trying to put together two routines, one to assign a variable to each of the attribute values within a selected block; and the other to assign a variable to each of the attribute values within a block (which the user will specify by an attribute value). These routines are for one specific block which has four attributes.
The purpose of the routine is to use the attribute values on our title block.
The first routine would select a block and then assign a value to the attributes: NOTE#, NOTE, ANSWER and SKETCH
The second routine would prompt the user for a Note Number (NOTE#) and then assign a value to the attributes: NOTE, ANSWER and SKETCH from the block with the specified note number.
I've been working on this for a little while now and have come to the realization that I'm going to need some help
Thanks in advance,
Larry
