Get attribute values
Message 1 of 13
I've been trying to put together two routines, one to assign a variable to each of the attribute values within a selected block; and the other to assign a variable to each of the attribute values within a block (which the user will specify by an attribute value). These routines are for one specific block which has four attributes.
The purpose of the routine is to use the attribute values on our title block.
The first routine would select a block and then assign a value to the attributes: NOTE#, NOTE, ANSWER and SKETCH
The second routine would prompt the user for a Note Number (NOTE#) and then assign a value to the attributes: NOTE, ANSWER and SKETCH from the block with the specified note number.
I've been working on this for a little while now and have come to the realization that I'm going to need some help
Thanks in advance,
Larry
Replies (12)
Message 2 of 13
hmsilva
Hi Larry,
It would be easier to help, if you post both codes, and a sample .dwg...
Henrique
Message 3 of 13
Hi Henrique,
I've been working on the routine this morning and I got the first routine to work. Below is the code.
Now I need to get the second routine to work, the one where the values are retrieved from a block with a certain note number. I haven't even tried to compile this routine yet.
(DEFUN C:GATTV()
(SETVAR "CMDECHO" 0)
(SETQ H(SSGET))
(SETQ I(ENTGET(SSNAME H 0)))
(SETQ ENAME(CDR(ASSOC -1 I)))
(SETQ F(ENTGET ENAME))
(SETQ TNAM(CDR(ASSOC 0 F)))
(IF(= TNAM "INSERT")(PROGN
(SETQ ENAME1(ENTNEXT ENAME))
(SETQ EN1(ENTGET ENAME1))
(SETQ NOTNUM(CDR(ASSOC 1 EN1)))
(SETQ ENAME2(ENTNEXT ENAME1))
(SETQ EN2(ENTGET ENAME2))
(SETQ NOT(CDR(ASSOC 1 EN2)))
(SETQ ENAME3(ENTNEXT ENAME2))
(SETQ EN3(ENTGET ENAME3))
(SETQ ANS(CDR(ASSOC 1 EN3)))
(SETQ ENAME4(ENTNEXT ENAME3))
(SETQ EN4(ENTGET ENAME4))
(SETQ SK(CDR(ASSOC 1 EN4)))
(PRINC))
Message 4 of 13
What I'm hoping to do with the second routine is to run it in paper space, even though the blocks are in model space.
Message 5 of 13
hmsilva
Post a sample .dwg with the blocks...
The block in model space, and the 'Note Number' in a layout...
Henrique
Message 6 of 13
sorry, forgot to add the drawing
the purpose of this is to be able to add drawing notes to the title block
Message 7 of 13
hmsilva
Hi Larry,
in model we have a dynamic block 'NOTE_FLAG1' with four attributes, NOTE#, NOTE, ANSWER and SKETCH.
In a layout we have a dynamic block 'NOTE#' with two attributes, NOTE and ANSWER.
So, let's see if I have understood.
you need to select the 'NOTE_FLAG1' in model, store the att values, select the 'NOTE#' in a layout, and copy NOTE# to NOTE, and ANSWER to ANSWER, I'm correct?
Henrique
Message 8 of 13
Very close
Although I haven't added it yet, the NOTE# block will be inserted with this routine.
So, you would select the 'NOTE_FLAG1' in model and store the attribute values.
Then in paper space the NOTE# block would be inserted.
At that point the value of NOTE# from the block NOTE_FLAG! will be added as the attribute for block NOTE#, and the value of NOTE from the block NOTE_FLAG1 will be written to the tiltle block.
Having two NOTE#'s may be making things a bit confusing.
The values from ANSWER and SKETCH are being retrieved but not being used at this point.
I hope I didn't confuse you more
Message 9 of 13
hmsilva
Hi Larry,
quick and dirty, and as a starting point.
Assumes "NOTE#" definition already exists, and I have declared 'att_lst' as a local variable, if you're gonna need the other attribute values for a later use, we'll have to add that in this code...
(vl-load-com)
(defun c:demo ( / att_lst atts atts1 obj obj1 pt s1 tab)
  (if (and
        (= (getvar "tilemode") 0)
        (= (getvar "cvport") 1)
    (if (setq pt (getpoint "\nSpecify \"NOTE#\" insertion point: "))
      (progn
        (setq tab (getvar 'CTAB))
        (setvar 'CTAB "Model")
        (if (and (setq s1 (ssget "_+.:E:S" '((0 . "INSERT") (66 . 1))))
                 (setq obj (vlax-ename->vla-object (ssname s1 0)))
                 (eq (vla-get-effectivename obj) "NOTE_FLAG1")
          (progn
            (setq atts (vlax-safearray->list (vlax-variant-value (vla-getattributes obj))))
            (foreach att atts
              (setq att_lst (cons (cons (vla-get-tagstring att) (vla-get-textstring att)) att_lst))
            (setvar 'CTAB tab)
            (setq obj1 (vlax-invoke
                         (vlax-get-property
                           (vla-get-activedocument (vlax-get-acad-object))
                           'paperspace
                         'insertblock
                         pt
                         "NOTE#"
                         1.0
                         1.0
                         1.0
                         0.0
            (setq atts1 (vlax-safearray->list (vlax-variant-value (vla-getattributes obj1))))
            (foreach att atts1
              (if (eq (vla-get-tagstring att) "NOTE")
                (vla-put-textstring att (cdr (assoc "NOTE#" att_lst)))
          (princ "\n\"NOTE_FLAG1\" not selected...")
    (princ "\nYou'll need to be in paper space to run this code... ")
  (princ)
Hope this helps,
Henrique
Message 10 of 13
That worked perfectly for inserting the "NOTE#" block with the note number
Now, I need to add this  (COMMAND "MTEXT" P1 "H" "0.1" "W" "3.65" NOT "")  to the routine. Where NOT is the value of the NOTE attribute from the block "NOTE_FLAG1"
I'll set the P1 variable
Message 11 of 13
hmsilva
As I said earlier
'Quick and dirty, and as a starting point.
Assumes "NOTE#" definition already exists...'
We'll have to test if "NOTE#" is already defined in dwg, if not, test if is found in SFSP...
(vl-load-com)
(defun c:demo (/ att_lst atts atts1 obj obj1 pspace pt s1 tab)
  (if (and
      (progn
          (progn
            (foreach att atts
            (setvar 'CTAB tab)
            (setq pspace (vla-get-paperspace (vla-get-activedocument (vlax-get-acad-object))))
                         pspace 'insertblock pt "NOTE#" 1.0 1.0 1.0 0.0)
            (foreach att atts1
            (setq
              obj (vla-addmtext pspace (vlax-3d-point (polar pt 0.435667 0.319844)) 3.7 (cdr (assoc "NOTE" att_lst)))
            (vla-put-height obj 0.1)
            (vla-put-width obj 3.65)
  (princ)
Hope this helps,
Henrique
Message 12 of 13
Ok Henrique,
I added the coding I needed to complete the routine.
Thank you very much for all your help. I definitely couldn't have done it without you.
Larry
Message 13 of 13
hmsilva
You're welcome, Larry!
Glad I could help
Henrique
