HOW TO GET THE AREA AND PUT THE VALUE IN EXISTING MTEXT
(defun c:UpdateAreaValue ()
(vl-load-com)
(setq layerName "BLOCK1")
(setq areaText "BLOCK1=")
(setq ss (ssget "X" (list (cons 8 layerName))))
(if ss
(progn
(setq obj (ssname ss 0))
(if (= (vla-get-ObjectName (vlax-ename->vla-object obj)) "AcDbText")
(progn
(setq areaValue "")
(setq entText (vla-get-TextString (vlax-ename->vla-object obj)))
(if (vl-string-search areaText entText)
(progn
(setq areaStart (vl-string-position areaText entText))
(setq areaValue (substr entText (+ areaStart (strlen areaText))))
(setq areaValue (strcase areaValue))
(if (/= areaValue "")
(alert (strcat "Area value found: " areaValue))
; Update MText value here
; Replace the following line with code to update the MText entity
(alert "Area value not found in MText")
(princ)
Solved by komondormrex. Go to Solution.
update existing mtext like in sample dwg.
(defun c:update_area_mtext ()
(setq pline_mtext_list (vl-remove-if 'listp (mapcar 'cadr (ssnamex (ssget '((0 . "lwpolyline,mtext"))))))
mtext_ename (car (vl-remove-if-not '(lambda (ename) (= "MTEXT" (cdr (assoc 0 (entget ename))))) pline_mtext_list))
mtext_string (vla-get-textstring (vlax-ename->vla-object mtext_ename))
pline_list (vl-remove mtext_ename pline_mtext_list)
(foreach pline pline_list
(setq pline_area (rtos (vla-get-area (vlax-ename->vla-object pline)) 2 2)
pline_layer (cdr (assoc 8 (entget pline)))
(if (setq layer_pos (vl-string-search pline_layer mtext_string))
(progn
(setq equal_pos (vl-string-search "=" mtext_string layer_pos)
next_paragraph_pos (vl-string-search "\\P" mtext_string equal_pos)
(if (null next_paragraph_pos)
(setq next_paragraph_pos (+ 2 equal_pos)
mtext_string (strcat (substr mtext_string 1 (+ 2 equal_pos))
pline_area
(setq mtext_string (strcat (substr mtext_string 1 (+ 2 equal_pos))
pline_area
(substr mtext_string next_paragraph_pos)
(vla-put-textstring (vlax-ename->vla-object mtext_ename) mtext_string)
(princ)
