Freeze a common layer in all open drawings
tfitzhardinge
tfitzhardinge
Hi
I'm new to scripting. Is there a way to freeze a common layer in all open drawings?
pbejse
ALL common layers? or enable the user to select which of the common names will be frozen?
tfitzhardinge
Thanks for your quick reply. Allow the user to specify a layer (which is common in all open drawings).
pbejse
You need to download this function LM:listbox here--> Lee Mac | List box function
Here's the general idea
(defun c:FCLDs ( / docs Alllayers docColl cnt ltfz )
	(setq Alllayers nil docColl nil);;<--- for debugging, you can remove this
	(vlax-map-Collection
	  (vla-get-documents (vlax-get-acad-object))
	  (function (lambda (itm / f lnm)
		      (setq docColl (cons itm docColl))
		      (vlax-for	l (Vla-get-layers itm)
			(setq Alllayers
			       (cond
				 ((setq
				    f (assoc (setq lnm (vla-get-name l)) Alllayers)
				  (cons	(list (car f) (cons l (cadr f)))
					(vl-remove f Alllayers)
				 ((cons (list lnm (list l)) Alllayers))
	(setq cnt (length docColl)
	       Alllayers (Vl-remove-if-not (function (lambda (ls)
				      (= (length (Cadr ls)) cnt))) Alllayers))
  	(setq ltfz (LM:listbox "Select layer name to freeze" (mapcar 'car Alllayers) 1))
  	(foreach itm ltfz
		   (foreach lay (cadr (assoc itm Alllayers))
		     (if (vl-catch-all-error-p
			     	(Vl-catch-all-apply 'vlax-put (list lay 'Freeze -1)))
		       (princ "\nLayer is current")
	;; 	saving the file to reflect the changes  on the rest of the inactive drawings;;
  	(mapcar 'vla-save docColl)
  (princ)
HTH
tfitzhardinge
Thanks for the solution. I'll try it out.
Is there was a lsp script solution to this. However I don't really know my options when it comes to scripting and coding options in autocad. Is it possible to run a lsp file with autocad commands through a batch file that targets drawings in a particle folder. I ran script pro 6 years ago and ran lsp file through it. I am under the impression that script pro doesn't receive any support.
pbejse
I see,  what you asked for, "in all open drawings", the posted code will do as you ask.
As for running through files on a folder. Yes Script pro is still in the mix
Try this.. https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/batch-freeze-thaw/td-p/6801628
;;                                  START Batch Freeze                           ;;
 command:batchfreeze
 command:c:batchthaw
Try codes posted at post # 1 & 4
post # 1 : prompts the user for a specific layer
Command: BATCHFREEZE
Specify layer to freeze <exit>: *Cancel*
post # 4 : List of layers present on the current drawing
and another dialog to select the files.
HTH
tfitzhardinge
@pbejse thank you so much for your assistance on this matter. I need to test out the solution but for now I'll accept the solution. I'll open it up if after I have done enough testing I have additional queries.
