3dface's Z coord becomes zero..
Hello, I've been trying to make 3dface in this way in AutoCAD 2021 version.
(defun c:MyTest()
  (setq p0 (list 168783.0 242367.0 1000.0))
  (setq p1 (list 154752.0 264514.0 750.0))
  (setq p2 (list 133763.0 247150.0 500.0))
  (command "3dface" p0 p1 p2 "" "")
However, when I run MyTest I found some vertices' Z coordinate become zero.
The picture shows that 3rd point's Z coordinate becomes zero.
It is very weird to me... 😞
I've been stuck in this issue for a week.. please help me.
Thanks in advance!
pbejse
Switch Object snap off [ F3 ]
or
(defun c:MyTest()
  (command "3dface" "_non"
	   p0 "_non" p1 "_non" p2 "" "")
or
(defun c:MyTest()
  (setq osm (getvar 'osmode))
  (setvar 'osmode 0)
  (setvar 'osmode osm)
  (princ)
HTH
Thank you so much! It works very well. I have one more question.
Is it possible to add texture to 3dface also? If possible, I want to give different colors to 3dfaces of each layers.
pbejse
Yes you can, You need to retrieve list of materials on your current drawing.
(setq matl (vla-get-materials (vla-get-activedocument (vlax-get-acad-object))))
(vlax-for itm matl
     (setq allmaterial (cons (vla-get-name itm) allmaterial))
assign material to newly created 3Dface
(Vla-put-material vlaobj materialname)
HTH
