Force block insertion from block definition within another drawing file
mspeace
mspeace
Hello all,
I have a lisp from way back that I am trying to bring current with some necessary changes.
I am trying to update my old lisp to utilize block definitions that are contained in a single .DWG. My old company had a library of individual .DWGs of each block so "-insert" worked fine.
My new company has a single .DWG that contains all of their blocks.
I'm trying to force an insert of the block from the library drawing regardless of if the block already exists in the current drawing, and even if its already been inserted and currently in use.
It looks like its very depended on whether or not the block contained in the library drawing has been updated or not, or differs form the one already defined in the current drawing.
I want to simply insert the block from the library drawing regardless. That way if its changed, it gets redefined, if it hasn't changed, it probably will still get redefined, but I don't care. I always want what is in the library drawing to be used.
I have attached the lisp I have currently but its just not doing all the necessary checks and conditionally inserting the block. I would appreciate a fresh set of eyes that may have a different approach to my logic.
cadffm
Hi
use a large complicated code way via API,
or use a translater abd read this post and following, incl. the last picture:
https://ww3.cad.de/foren/ubb/Forum145/HTMLna/005002.shtml#000012
Sebastian
paullimapa
Could you also share the dwg the lisp references:
C:\\RICK_C3D\\C3D_RICK_NCS_2022\\Resources\\DEN\\DEN_GENERAL.dwg
But just taking a quick look at the routine it seems to check for the existence of the block definition in the current drawing and includes code to handle one way vs another for inserting the following 2 blocks:
"ARV_RICK_LOGO_EXHIBIT_COLOR"
"DEN-ARRW_2_COLOR"
   (if(tblsearch "block" "ARV_RICK_LOGO_EXHIBIT_COLOR")
           (command "-INSERTCONTENT" "C:\\RICK_C3D\\C3D_RICK_NCS_2022\\Resources\\DEN\\DEN_GENERAL.dwg" "ARV_RICK_LOGO_EXHIBIT_COLOR" "Y" "7.5995,0.475,0" "" "" "")
           (command "-INSERTCONTENT" "C:\\RICK_C3D\\C3D_RICK_NCS_2022\\Resources\\DEN\\DEN_GENERAL.dwg" "ARV_RICK_LOGO_EXHIBIT_COLOR" "7.5995,0.475,0" "" "" "")
     );END IF
   (if(tblsearch"block""DEN-ARRW_2_COLOR")
          (command "-INSERTCONTENT" "C:\\RICK_C3D\\C3D_RICK_NCS_2022\\Resources\\DEN\\DEN_GENERAL.dwg" "DEN-ARRW_2_COLOR" "Y" (getvar "viewctr") "" "" vtwst)
          (command "-INSERTCONTENT" "C:\\RICK_C3D\\C3D_RICK_NCS_2022\\Resources\\DEN\\DEN_GENERAL.dwg" "DEN-ARRW_2_COLOR" (getvar "viewctr") "" "" vtwst)
     );END IF
Exactly what is not working?
Paul Li
IT Specialist
@The Office
cadffm
@mspeace
1. Set cmdecho to 1 (in your code) to check where it goes wrong.
2. Run tests ONLY in new opened files!
    (Because your code does work only once in your file session, this is what I talked  about in the linked german thread)
Sebastian
