FLATSHOT from lisp
FLATSHOT from lisp
Message 1 of 8
FLATSHOT from lisp
Hi
it is possible to run FLATSHOT from lisp and to set the parameters?
If not is there any other routine, that works like FLATSHOT, that I can control from lisp?
Thanks Guido
Replies (7)
Message 2 of 8
kerry_w_brown
Try this
https://www.theswamp.org/index.php?topic=33105.0
The attachment in the first post has ALL the required files.
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Message 3 of 8
Hi Kerry
thanks for that ingeniously routine.
I have added SURFACE and REGION to the SelSet-filter because they are also used from FLATSHOT.
And I added a routine that unlocks all layers before your main routine, and that locks the layers after your main routine, else an error occurs if you have locked layers in the drawing.
Guido
Message 4 of 8
marko_ribar
This may also interest you... It creates FLATSHOT at the same place as your 3D MODEL...
http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/flatshot-insertion-point/m-p/5562259/...
M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 5 of 8
sig.johnson
The Swamp appears to be no longer accessible. If you still have the attached files you mentioned, would you be able to share them directly here?
Message 6 of 8
pendean
Community Legend
Community Legend
Seems to be working just fine: are you just shy about signing up for free for access?
Message 7 of 8
john.uhden
@pendean
Been thinking about this for a while.
That image of you is a recent photo, right? 🙃
Looking forward to 2nd grade?  I mean teaching, of course.
Can kids understand AutoCAD before the age of reason? 🤔
John F. Uhden
Message 8 of 8
sig.johnson
No issue with signing up -- I just get a connection timeout.
Thanks for confirming, sounds like a problem for my IT.
