Flat centerline of a plate
jotaferrer
Message 1 of 22
jotaferrer
Here I am again, guys!
I need a routine that takes a plate and creates a continuos line based on the centerline of a polyline or its vertex (the easiest option) as you can see in the example bellow. Can someone please help me or at least guide me in the process? Thank you in advance!
Replies (21)
Message 2 of 22
calderg1000
Regards @jotaferrer
Hope this helps something.
(defun c:lpl (/ e s lp lt)
  (setq
    spm (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object)))
  (setq e  (Getreal "\nEnter Plate thickness...:")
        lp (vla-get-length
             (vlax-ename->vla-object (car (entsel "\n Select Plate..:")))
  (setq lt (/ (- lp (* 2 e)) 2))
  (vla-addline spm
               (vlax-3d-point (setq p1 (getpoint "\nEnter Result Location...:")))
               (vlax-3d-point (mapcar '+ p1 (list lt 0 0 0)))
  (princ lt)
  (princ)
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
Message 3 of 22
Sea-Haven
I am not a folding plate person but does not the min radius affect the true length ?
Message 4 of 22
ВeekeeCZ
You can try @Kent1Cooper 's unfold... but it does not do a centerline.
Message 5 of 22
hak_vz
As long as shape is symmetrical to center line result is OK
Miljenko Hatlak
Message 6 of 22
hak_vz
I guess that better way to create deformed plate element would be to use double offset from center line. First create center line and then offset to both sides and join to single polyline. We have similar request before so searching through older post may bring up something useful.
Miljenko Hatlak
Message 7 of 22
jotaferrer
Thanks for your answer @calderg1000
It works indeed! But is there a way to keep the vertext when the line is drew? If it does, there will be my solution 😅
Thank you again!
Message 8 of 22
jotaferrer
Thank you again @ВeekeeCZ it work well but I need to explode the plate or create the centerline... I'm going to try to fit his code for my needs. Thanks man!
Message 9 of 22
jotaferrer
Yeah, that's right!
Message 10 of 22
jotaferrer
That's the way I do too. I'll give another try because I had already searched before. Thanks for you answer!
Message 11 of 22
calderg1000
Regards @jotaferrer
If the code helps in your case I am very happy. Although because of the language, I do not interpret very well what you request, additionally I try to understand that you want the result with an automatic grip point. Here I made a little change.
(defun c:lpl2 (/ spm e s lp lt p1)
  (setq
        s  (vlax-ename->vla-object (car (entsel "\n Select Plate..:")))
        lp (vla-get-length s)
  (vla-addline spm
               (vlax-3d-point (setq p1 (vlax-curve-getStartPoint s)))
  (princ lt)
  (princ)
Carlos Calderon G
Message 12 of 22
jotaferrer
Thanks for your fast answer! But it didn't change, sadly...
Can you do something like the Kent1Cooper did in the lisp posted above? I liked your way to "get the plate" but I need something like he did. When the straight plate is drew, I'd like to draw a polyline with the grips where it changes its direction.
I can explain it better in the chat in your language though.
Message 13 of 22
leeminardi
Not necessarily, to be precise the bend allowance should be considered.
lee.minardi
Message 14 of 22
jotaferrer
I think a print screen would do a better explanation...
1-Select the plate (closed polyline)
2-Create a centerline with radius zero
3-Draw a polyline with the segments lengths based on centerline
Message 15 of 22
Kent1Cooper
[>Here< is the source of that routine with its original command name and context, in case you're interested.]
Manually, assuming the profile is a single closed Polyline, I would suggest TRIMming away the short end segments, OFFSETting one of the resulting two Polylines to halfway between the two for a center-line path, and using the SPS command [under whatever name] on that.
To automate that could be a challenge, depending on certain things:
Does the Polyline always start at one of the ends?  If so, is the first segment always the short end one, or always the one extending from there along the length of the profile, or might the starting point be anywhere?
Are they always Z-shaped [i.e. two and only two bends], or might they sometimes be L-shaped [one bend] or have more than two bends?
Kent Cooper, AIA
Message 16 of 22
Kent1Cooper
So now that I see your image, I just want to clarify:  You don't want a result like this?
If that's the case, the manual approach I suggested before would need to include FILLETing the center-path Polyline with Zero radius before SPSing it.  But I think the same questions would apply.
Kent Cooper, AIA
Message 17 of 22
jotaferrer
Thanks for you answer @Kent1Cooper !
For sure I'm interested in your source code. As long as I'm still a toddler when it comes to lisps, I'm like studying every single code I can hehe
About the Polyline ends: the first segment is always the shortest one and there will be more than two bends.
A result like your lisp gives it's perfect, as long as I draw the centerline which is pretty easy to do, but I think it'd be even more perfect if it was automated.
You know the pain to expand a plate, don't you? xD
Message 18 of 22
jotaferrer
I think it's better to answer you in a single post, buddy
Message 19 of 22
Kent1Cooper
If that is truly always the case, and if all bends are always radiused, try this [in simplest terms, minimally tested]:
(defun C:SPCLS ; = Stretch Polyline CenterLine Straight
  (/ pl1 verts pl2 pl3 lengths)
  (setq
    pl1 (car (entsel "\nSelect bent-plate section profile: "))
    verts (cdr (assoc 90 (entget pl1)))
  ); setq
  (command "_.pedit" pl1 "_edit" "_Break" "_next" "_go")
  (repeat (1- (/ verts 2)) (command "_next")); move around to break at other end
  (command "_break" "_next" "_go" "_exit" "")
  (setq pl2 (entlast))
  (command "_.offset" "_through" pl1 "_m2p" (vlax-curve-getStartPoint pl1) (vlax-curve-getEndPoint pl2) "")
  (setq pl3 (entlast))
  (setvar 'filletrad 0)
  (command "_.fillet" "_polyline" pl3); take out radii at bends
  (repeat (setq par (fix (vlax-curve-getEndParam pl3)))
    (setq lengths ; list of segment lengths
      (cons
        (- ; length of segment ending at parameter
          (vlax-curve-getDistAtParam pl3 par)
          (vlax-curve-getDistAtParam pl3 (setq par (1- par)))
        lengths
      ); cons
    ); setq [lengths]
  ); repeat
  (command "_.pline" (getpoint "\nStart of straightened path: "))
  (repeat (length lengths); feed segment lengths out to Pline
    (command "_none" (polar (getvar 'lastpoint) 0 (car lengths)))
    (setq lengths (cdr lengths))
  ); repeat
  (command "")
  (princ)
Kent Cooper, AIA
Message 20 of 22
ВeekeeCZ
Does it matter where it's picked? It does not seem to work well...
Since I was thinking of a similar workflow, I made smaller adjustments... which works for me.
       (/ pl1 pt1 verts pl2 pl3 lengths)
  (setq
    pl1 (entsel "\nSelect bent-plate section profile at thin side: ")
    pt1 (cadr pl1)
    pl1 (car pl1)
    ); setq
  (command "_.undo" "_mark")
  (command "_.trim" "" "_non" pt1 "")
  (command "_.pedit" pl1 "_edit")
	   (cons
	     lengths
	     ); cons
	  ); setq [lengths]
    ); repeat
  (command "_.undo" "_b")
    ); repeat
  (command "")
  (princ)
