Fixed Saving-Path for Logfile from a LISP-Code
Hello everyone,
the situation is as follows:
I use a Lisp script in ACA which writes a log file at the end. Now It is programmed that the LOGFile will always be placed in the location of the DWG file, that I am applying the script to. Sometimes it doesn't work for some inexplicable reason, so I wanted to specify a fixed saving-location, e.g. "C: / Temp" What is the order for that?
Here is my previous code for flexible saving.
(Defun WriteLogT (textzeile / filename Logdatei)
(setq filename (if (> (vl-string-search "\\" (getvar "DWGNAME") 0) 0)
(getvar "DWGNAME")
(strcat (getvar "DWGPREFIX") (getvar "DWGNAME"))
(if (setq Logdatei (open (strcat filename "Logdatei.LOG") "a"))
(progn
(write-line (vl-string-subst "" "\n" Textzeile) Logdatei)
(close logdatei)
Perhaps you can use that to find a solution.
Thank you
Erik
ВeekeeCZ
Possibly like this?
(Defun WriteLogT (textzeile / Logdatei)
  (if (setq Logdatei (open "c://Temp//Logdatei.LOG" "a"))
    (progn
      (close logdatei))))
Thanks for the fast reply!
How i have to rewrite your code to us a alternate Filename?
In my case, the Logname depends on the DWG name wich the LISP applied to.
Like this:
yxz.dwg --> yxz-Log.log
123.dwg --> 123-Log.log
I tried to use my original string, but doesn't work.
(Defun WriteLog (textzeile)
(if (setq Logdatei (open c://Temp// (strcat (getvar "DWGNAME") "-XYZ.LOG") "a"))
(progn
(close logdatei)
Maybe you have a clue.
Thanks a lot
Erik
ВeekeeCZ
... then you can fix it using THIS  fnc
