Finding the smallest number
Henrik_Lo
Message 1 of 15
Henrik_Lo
HI
I’ll like to knot the smallest number form 4 different variables ,
but I need to keep track of the variable name.
Example.
Ba1 =3
Ba2 = 14
Ba3 = 40
Ba4 = 10
(min ba1 ba2 ba3 ba4)
Returns 3, but I need to know it is ba1
Regards
Henrik
Replies (14)
Message 2 of 15
Sea-Haven
Use a double list ((4 bal1)(45 bal5)(12 bal3)……… sort on X you will need to look at set read and eval though to get the variable name its a lambda thing which I am not very good at.
(setq lst (list '("ba1" 1) '("bal2" 23) '("bal3" 12) '("bal4" 15)))
sort list on 2nd item cadr.
(set (read (car (nth 1 lst)))(cadr (nth 0 lst)))
Message 3 of 15
marko_ribar
(cond
  ( (= ba1 (min ba1 ba2 ba3 ba4))
    (setq tmp ba1)
  ( (= ba2 (min ba1 ba2 ba3 ba4))
    (setq tmp ba2)
  ( (= ba3 (min ba1 ba2 ba3 ba4))
    (setq tmp ba3)
  ( (= ba4 (min ba1 ba2 ba3 ba4))
    (setq tmp ba4)
do with tmp all like you wanted with ba* (min)
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 4 of 15
cadffm
For a long list of variables
use vl-sort-i and vl-position
Sebastian
Message 5 of 15
_gile
You can try this:
(defun minSym (l)
  (nth (car (vl-sort-i (mapcar 'eval l) '<)) l)
(minSym '(ba1 ba2 ba3 ba4)) returns BA1.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 6 of 15
Sea-Haven
Nice idea , so rather than multiple conds with unknown number of variables could write a script (foreach val '(bal1 bal2.…..
Have to find it again send a string which is lisp of your cond to the command line as its repeated but with new BalX.
Message 7 of 15
Henrik_Lo
HI all
Tangs a lot, simply a fantastic forum, tangs for helping med out
Regards
Henrik
Message 8 of 15
_gile
You can also use a 'reduce' function.
(defun reduce (fun lst)
  (setq fun (eval fun))
  (while (cdr lst)
    (setq lst (cons (fun (car lst) (cadr lst)) (cddr lst)))
  (car lst)
(reduce '(lambda (a b) (if (< (eval a) (eval b)) a b)) '(ba1 ba2 ba3 ba4)) return BA1
Gilles Chanteau
GileCAD
GitHub
Message 9 of 15
hak_vz
(defun set_min (lst)(mapcar 'set '(Ba1 Ba2 Ba3 Ba4)(vl-sort lst '<)))
(set_min '(40 30 20 10)) ->(10 20 30 40)
!ba1 -> 10
!ba2 -> 20
!ba3 -> 30
!ba4 -> 40
This way ba1 will allways hold smallest value and ba4 will be largest
!ba1 -> 10
!ba2 -> 20
!ba3 -> 30
!ba4 -> 40 ​
Miljenko Hatlak
Message 10 of 15
hak_vz
Let say you have run some code and instead of checkin which of vars in minimal you can reasign them all in a range from ba1 to ba4
;let say this are results of some previous calculations
(setq ba1 50.2 ba2 30.3 ba3 70.4 ba4 10.4)
;we assign values to new list p
(setq p (list ba1 ba2 ba3 ba4))
; and reassign values to vars ba1 ..ba4
(set_min (list ba1 ba2 ba3 ba4))
!ba1 -> 10.4
!ba2 -> 30.3
!ba3 -> 50.2
!ba4 -> 70.4
Miljenko Hatlak
Message 11 of 15
marko_ribar
@marko_ribar wrote:
(cond
    (setq tmp ba1)
    (setq tmp ba2)
    (setq tmp ba3)
    (setq tmp ba4)
Still I don' quite undertand what OP wants to achieve... Without (cond), why this couldn't all be simply :
(setq tmp (min ba1 ba2 ba3 ba4))
And 'tmp' could be used instead of any 'ba*'...
Message 12 of 15
Kent1Cooper
I thought it was pretty clear in Message 1 -- they want to know which of the variable names  holds the smallest value, not what that smallest value is, which is what that expression returns.
Kent Cooper, AIA
Message 13 of 15
marko_ribar
Then simply :
(setq tmp
  (cond
    ( (= tmp ba1)
      "ba1"
    ( (= tmp ba2)
      "ba2"
    ( (= tmp ba3)
      "ba3"
    ( (= tmp ba4)
      "ba4"
(princ tmp)
Message 14 of 15
marko_ribar
Another one more succinct...
(defun smallestvar ( lstvars / l minval minvar )
  (setq l (mapcar 'eval lstvars))
  (setq minval (apply 'min l))
  (setq minvar (vl-some '(lambda ( x ) (if (= (eval x) minval) x)) lstvars))
  minvar
(setq lstvars '(ba1 ba2 ba3 ba4))
(setq ba1 10.0 ba2 5.0 ba3 15.0 ba4 20.0)
(princ (smallestvar lstvars))
(princ)
HTH.
Message 15 of 15
Kent1Cooper
Would it always be 4 and only 4?  It appears some of the things suggested here so far depend on that, so you would need different versions for different numbers of variables, but others presumably could work with any number of them.
Kent Cooper, AIA
