Find centre of object or goup of objects?
Message 1 of 20
I would like to be able to find a centre of an assymetrical object or of multiple objects when considered together. This would be either just for information or to be able to rotate around that centre.
Replies (19)
Message 2 of 20
Kent1Cooper
This has come up before.  I remember something that stepped through a selection and checked the extents of the bounding box of each object, and changed the overall extents out if they went beyond what was already checked.  It would then be a simple thing to find the midpoint between opposite corners of the result.  I didn't find that in a quick search, but did find this, which should get those extents for you, but I haven't looked into the form of what it returns for calculating the middle.
Kent Cooper, AIA
Message 3 of 20
M_Hensley
If the objects are closed polylines you could convert them to regions then union them into one object and use massprop to get the coordinates of the centroid.
Message 4 of 20
Wow, I have to be honest; I don't follow either of those. I don't know LISP so I would only be able to use a ready-made, finished LISP routine. But I will look into the region thing and let you know.
I am amazed AutoCAD doesn't have this kind of functionality. Its seems simple.
Message 5 of 20
Kent1Cooper
@Anonymous wrote:
Wow, I have to be honest; I don't follow either of those. ....
It is pretty simple, if not built in.  Here's a way to get that using the (acet...) function in the link in my earlier Reply, independently of how the result is to be used:
(defun C:MIDSS (/ ss extss)
  (prompt "\nTo find the midpoint of a selection,")
  (if (setq ss (ssget))
    (progn ; then
      (setq
        extss (acet-geom-ss-extents ss t)
        midss (mapcar '/ (mapcar '+ (car extss) (cadr extss)) '(2 2 2))
      ); setq
      (prompt "\nMidpoint saved in MIDSS variable.")
    ); progn
    (prompt "\nNothing selected."); else
  ); if
  (princ)
); defun
You can do that and then use !MIDSS [with the initial exclamation point; not case-sensitive] to use that location in response to a prompt such as for the base point in a Rotation command.  Or the functionality can be built into a larger routine, and supply its result internally at the appropriate place.
Kent Cooper, AIA
Message 6 of 20
nhatquyelec
Hi sir,
I tried your lisp that your, but it not show me anything.
Message 7 of 20
Kent1Cooper
@nhatquyelec wrote:
.... I tried your lisp that your, but it not show me anything.
It's not designed to show you anything.  It puts the midpoint into a variable, as a point coordinates list, which you can then use in a variety of ways.  What happens when you follow the instructions at the end of my previous Message?
Kent Cooper, AIA
Message 8 of 20
nhatquyelec
I has attached a picture, that I caught screenshot, you can see it
Message 9 of 20
Alfred.NESWADBA
so in case you have a closed polygon and want to get it's center using the object snap _GCEN ... used this:
  • _ID<ENTER>
  • _GCEN<ENTER>
  • <pick your closed polyline>
...your command-line now shows what the object snap _GCEN has found as center, you might also use
  • _LINE<ENTER>
  • _GCEN<ENTER>
  • <pick your endpoint for the line>
... your line starts now in the center of the polyline.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 10 of 20
vladimir_michl
You can use the CenOf utility - see www.cadstudio.cz/freeware. Just download the .LSP file and drag it to your AutoCAD window (or use APPLOAD). You can then type CENOF to draw the center point (XYZ) of selected objects or you can use 'CENOF transparently anywhere AutoCAD prompts for a point coordinate.
Regards
Vladimir Michl, www.cadstudio.cz - www.cadforum.cz
Message 11 of 20
Kent1Cooper
As it tells you, it has put the midpoint into the MIDSS variable [which stands for MIDpoint of a Selection Set].
Repeating from Message 5, type !MIDSS to see it as a point coordinates list at the command line, or to use it inside a command that asks for a point, such as for the base or destination point of a COPY or MOVE command, an endpoint of a LINE, etc.
Use it in any other way that code can use variables, without the exclamation-point prefix if used in AutoLisp expressions.
Kent Cooper, AIA
Message 12 of 20
nhatquyelec
Thanks, but I want to export them
Message 13 of 20
nhatquyelec
i has not found LISP in URL that you sent
Message 14 of 20
vladimir_michl
It is there (Ctrl+F for "CenOf") but the list is rather long - try https://www.cadstudio.cz/en/download.asp?file=CenOf
Message 15 of 20
Alfred.NESWADBA
Then create a point or block with _GCEN as object snap and use command _DATAEXTRACTION to export them.
What is the goal at least?
- alfred -
Alfred NESWADBA
Message 16 of 20
nhatquyelec
Thanks for lisp that was sent by vladimir.michl, but it manually, how way is export all automatically (centroid of lines, circles, texts, rectangles,...)
And i have attached a picture to explain my purpose
Message 17 of 20
vladimir_michl
It is a quite different task but can be done. The updated version of the CenOf utility now contains also the command CenOf1 which takes the selected objects individually and draws their center points. You can then make a schedule of their coordinates with EXTRDATA.
Message 18 of 20
nhatquyelec
sorry, i couldn't find that lisp (cenof1), please give me directly
Message 19 of 20
cadffm
Sebastian
Message 20 of 20
nhatquyelec
thank you, I've got it
