Change surface build settings via lisp
Hi everybody,
I am trying to access the tin surface build settings and more specifically the definition build options "Use maximum angle" and "Use maximum triangle length". When I list the surfaces as a vla-object I cannot see that properties available, meaning that vlax-put-property will not work .
Is there any other place or way to reach it and change it to Yes or No/ True or False?
So far I was trying with lisp, but I am open for any other solutions.
We are using some additional custom made programs for joining surfaces, which need that option to be disabled.
Anybody with any idea??
I tryed so many things with no sucsess yetSmiley Sad
