FIND AND REPLACE USING AUTOLISP
sHubamyadav016
sHubamyadav016
I tried to do manually find and replace command it work perfectfully but how to do with autolisp like I have  a drawing I want like through code I can select a drawing and after selecting I can replce text with any other text how to do it
Moshe-A
@sHubamyadav016  hi,
You are aiming very high 🤣, FIND is a very strong command with dialog interface that scans the database as a whole working on texts, mtexts, dimensions, leaders and block attributes. cloning such a command require a lot of coding but to give a tiny touch on what that involve, here is MFIND command to find & replace on selected texts objects.
(defun c:mfind (/ text_replace ; local function
		  FWhat RWith i ename ;| local variables |;)
 (defun text_replace (ent oldStr newStr / edata text)
  (setq edata (entget ent))
  (setq text (cdr (assoc '1 edata)))
  ; loop to replace duplicate oldStr
  (while (vl-string-search oldStr text)
   (setq text (vl-string-subst newStr oldStr text))
  ; update entity database
  (entmod (subst (cons '1 text) (assoc '1 edata) edata))
 ); text_replace
 ; here start c:mfind
 (if (and
       (/= (setq FWhat (getstring "\nFind what: ")) "")
       (/= (setq RWith (getstring "\nReplace width: ")) "")
       (setq ss (ssget '((0 . "text"))))
  (progn
   (setq i -1)
   (repeat (sslength ss)
    (setq i (1+ i))
    (setq ename (ssname ss i))
    (text_replace ename FWhat RWith)
   ); repeat
  ); progn
 ); if
 (princ)
); c:mfind
enjoy
Moshe
sHubamyadav016
If I will not aim high why will I  post on Autodesk Community 😀 I expect your level is too much high 😎
cadffm
more flexible, more to your needs and customable, than FIND
+ If you have lisp programming skills, it's easy to create the another way for start&run:
The very big main function is offered here: Click
Sebastian
CGBenner
@sHubamyadav016
Hi, Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
