Message 1 of 9
Find and Replace updating block mtext in modelspace but not within block
Strange issue here that I've been puzzling about this morning, hoping I can find some help here. Was hoping to run the find and replace command to change the listed sizing of our structural elements in a drawing. The command correctly finds and replaces all instances of the dimensions (changing 192cm 194cm in this case) for every instance of the text with the exception of mtext objects within blocks. These mtext objects update in modelspace only, while retaining the initial value of the mtext within the block. Exploding the block keeps the replaced mtext shown in modelspace. I've included an example file reproducing the issue. Is there a potential solution for this?
