- Mute
- Permalink
- Report
This is a lsp that seams a little faster to me than the find command.
It selects windowed text strings.
Does anyone know how to change it to select only “__” with-in the text string.
I use the double underscore in my titles for grouping that need to be renamed.
; CHGTEXT.LSP
; CHANGES TEXT GLOBALLY
; This program will replace every occurrence of an "old string" with a
; "new string".
(defun chgterr (s)
(if (/= s "Function cancelled")
(princ (strcat "\nError: " s))
(setq p nil)
(setq *error* olderr)
(princ)
(defun C:CHGTEXT (/ p l n e os as ns st s nsl osl sl si chf chm olderr)
(setq olderr *error*
*error* chgterr
chm 0)
(setq p (ssget))
(if p (progn
(while (= 0 (setq osl (strlen (setq os (getstring t "\nOld string: ")))))
(princ "Null input invalid")
(setq nsl (strlen (setq ns (getstring t "\nNew string: "))))
(setq l 0 n (sslength p))
(while (< l n)
(if (= "TEXT"
(cdr (assoc 0 (setq e (entget (ssname p l))))))
(progn
(setq chf nil si 1)
(setq s (cdr (setq as (assoc 1 e))))
(while (= osl (setq sl (strlen
(setq st (substr s si osl)))))
(if (= st os)
(progn
(setq s (strcat (substr s 1 (1- si)) ns
(substr s (+ si osl))))
(setq chf t)
(setq si (+ si nsl))
(setq si (1+ si))
(if chf (progn
(setq e (subst (cons 1 s) as e))
(entmod e)
(setq chm (1+ chm))
(setq l (1+ l))
(princ "Changed ")
(princ chm)
(princ " text lines.")
(terpri)
(princ)
