find a dynamic bloc
find a dynamic bloc
tarin_lc
find a dynamic bloc
tarin_lc
Here is a LISP code to find the coordinates of a block. It works perfectly except in the case of a dynamic block, which doesn't find it. What could I change to find the coordinates or other properties of a dynamic block?
thanks a lot !
Sea-Haven
This will find dynamic blocks in a layout
(setq ss (ssget "X" (list (cons 0 "INSERT")(cons 2 "*U*")(cons 410 (getvar 'ctab)))))
You can then get properties like layer and Insertionpoint. You can go deeper and get the dynamic properties. I would also look at Effectivename which is original block name.
komondormrex
hi,
change in the code
this
(if (= (vla-get-Name item) "1")
for that
(if (= (vla-get-effectiveName item) "1")
tarin_lc
Perfect!
Thanks for all guys 🙂
