Fillet polyline with arc not working
eakos1
Message 1 of 11
eakos1
If a polyline ended in an arc it is not possible make the fillet with an arc, it gives always the respond: Cannot fillet between these two entities. This is very annoying, we have to do it very often.
Just an example.
Even if I draw two arcs but one of them is polyline the fillet isn't working.
Do someone wrote a lisp for it? I tried to find on the net but with no result.
Replies (10)
Message 2 of 11
Kent1Cooper
This has always been a limitation.  Until they decide to change that, it's a little less immediate, but EXTEND and TRIM can get you where you want to go [including the appropriate Edge-extension setting].  If you need a non-zero Fillet radius, you can achieve that with CIRCLE's Tangent-Tangent-Radius option and then some Trimming.  Or if there are no widths involved [as there are not in your examples], you can EXPLODE a Polyline, do the FILLET operation(s), and rejoin the results into a Polyline again.
[But no, I don't have anything like a routine to offer.]
Kent Cooper, AIA
Message 3 of 11
eakos1
I've just made the code myself.
After selection of a LWPOLYLINE you can select a LINE/ARC/LWPOLYLINE and the program can make the fillet, finally the program join them to one polyline.
Message 4 of 11
CADaSchtroumpf
Wouldn't it be easier to do the opposite instead of EXPLODE to JOIN later, make rather a PEDIT on Arc or Line?
Example:
(defun C:fillet_pline&line ( / ss1 ent1 pt_sel1 ss2 ent2 typ_ent pt_sel2)
  (princ "\nSelect a LWPOLYLINE: ")
  (while
    (not
      (setq ss1
        (ssget "_+.:E:S"
          (list
            (cons 0 "*POLYLINE")
            (cons -4 "<NOT")
              (cons -4 "&") (cons 70 112)
            (cons -4 "NOT>")
  (setq
    ent1 (ssnamex ss1 0)
    pt_sel1 (cadar (cdddar ent1))
  (princ "\nSelect a LINE/ARC/LWPOLYLINE: ")
  (while
    (not
      (setq ss2
        (ssget "_+.:E:S"
          (list
            (cons -4 "<AND")
              (cons 0 "*POLYLINE,LINE,ARC")
              (cons -4 "<NOT")
              (cons -4 "NOT>")
            (cons -4 "AND>")
  (setq
    ent2 (ssnamex ss2 0)
    typ_ent (cdr (assoc 0 (entget (cadar ent2))))
    pt_sel2 (cadar (cdddar ent2))
  (cond
    ((member typ_ent '("LINE" "ARC"))
      (command "_.pedit" pt_sel2 "_yes" "")
  (command "_.fillet" pt_sel1 pt_sel2)
  (prin1)
Message 5 of 11
Sea-Haven
The issue of FILLET not working has been in Acad since it first came out. A simple example is two arcs add a third arc in between the two arcs by using fillet, It often draws a "S". Other software has purpose written programs to get around this problem, they existed back in the 80's. As suggested by @Kent1Cooper using the Circle TTR option is often the only way to get a result. Bottom is original two arcs, middle is circle TTR, top is fillet.
@CADaSchtroumpf tried code and got an error I use Bricscad normally.
(setq
; ----- Error around expression -----
; (CDDDAR ENT1)
; error : bad argument type <-1> ; expected <CONS> at [cdr]
Message 6 of 11
eakos1
This code is very simple but not works well, because not considers which side is the start and end point of the polyline, and it doesn't matter.
I've mad for me 4 possible combinations.
Your code make the fillet in certain cases the wrong way. So I think there is no other way, always should be checked were is the selection point and the relative positions of the to polylines.
Message 7 of 11
komondormrex
@eakos1
have you tried that simple one
(command "_fillet" "_t" "_t" pause pause)
Message 8 of 11
eakos1
Not always works.
But intresting, in case of polyline this simple code not works, only with ARC and LINE.
My idea was to draw the fillet without trim and with entlast get the name and with trim just trim the polylines. But in case of polylines not draws the arc.
(setq a (entsel))
(setq b (entsel))
(command "_fillet" "_t" "_n" a b )
(entlast)
(trim ......)
Message 9 of 11
komondormrex
which version of autocad do you use? in 26 there is the only pair when fillet doesn't come when you filleting an arc with pline's line segment. other pairs fillet okay.
Message 10 of 11
Sea-Haven
Re new arc is upside down found this today for something else, if using Circle TTR picking clockwise or anticlockwise will draw in the two different directions. Does not work for plain Fillet command.
Message 11 of 11
eakos1
I use AutoCAD 2015
