Fillet polyline error (Autolisp)
kinakira2013
kinakira2013
Hello there,
I have a code connecting some blocks by polylines (please refer to the code below). I have trouble with the result, it has not worked as well.
(defun draw-pline-between-blocks (bl1 bl2 offset)
  "Function to draw a polyline between two blocks with a fillet at pt2 and pt3, and a customizable offset."
  (if (and bl1 bl2)  ; Check if both blocks are valid
    (progn
      ;; Get the coordinates of the blocks
      (setq p1 (cdr (assoc 10 (entget bl1)))) ; Coordinates of the first block
      (setq p2 (cdr (assoc 10 (entget bl2)))) ; Coordinates of the second block
      ;; Assign coordinates to variables x1, y1, x2, y2
      (setq x1 (car p1) y1 (cadr p1)) ; Coordinates of the first block
      (setq x2 (car p2) y2 (cadr p2)) ; Coordinates of the second block
      ;; Create a list of points based on the conditions described
      (cond
        ((and (/= x1 x2) (/= y1 y2))  ; If x1 ≠ x2 and y1 ≠ y2
         (setq pt1 (list x1 y1)
               pt2 (list (+ x1 offset) y1)
               pt3 (list (+ x1 offset) y2)
               pt4 (list x2 y2)))
        ((= x1 x2)  ; If x1 = x2
         (if (> y1 y2)
                 pt2 (list (- x1 offset) y1)
                 pt3 (list (- x1 offset) y2)
                 pt4 (list x2 y2))
                 pt4 (list x2 y2))))
        ((= y1 y2)  ; If y1 = y2
         (if (< x1 x2)
                 pt2 (list x1 (- y1 offset))
                 pt3 (list x2 (- y1 offset))
                 pt4 (list x2 y2))
                 pt4 (list x2 y2))))
      ;; Print the coordinates of the points to the screen
      (princ (strcat "\nCoordinates of pt1: " (rtos (car pt1) 2 3) ", " (rtos (cadr pt1) 2 3)))
      (princ (strcat "\nCoordinates of pt2: " (rtos (car pt2) 2 3) ", " (rtos (cadr pt2) 2 3)))
      (princ (strcat "\nCoordinates of pt3: " (rtos (car pt3) 2 3) ", " (rtos (cadr pt3) 2 3)))
      (princ (strcat "\nCoordinates of pt4: " (rtos (car pt4) 2 3) ", " (rtos (cadr pt4) 2 3)))
      (command "_.FILLET" "_R" 200) ; Set the fillet radius
      ;; Draw the polyline through the defined points
      (command "_.PLINE" pt1 pt2 pt3 pt4 "")
      ;; Apply fillet at pt2 and pt3 with a radius of 200mm
      (command "_.FILLET" "_P" pt2 pt3)
    (princ "\nYou need to select 2 valid blocks!") ; Error message when blocks are not valid
  (princ)
(defun c:ss ()
  "Command to select a list of blocks and draw a polyline sequentially between each pair with a customizable offset."
  (setq offset (getreal "\nEnter the offset distance (default 500mm): "))
  (if (not offset) (setq offset 500)) ; Default value if none is entered
  (setq block-list nil)
  (princ "\nSelect the list of blocks.")
  (setq bl (car (entsel "\nSelect the first block (press Enter to finish): ")))
  ;; Loop to select blocks
  (while bl
    (setq block-list (append block-list (list bl)))
    (setq bl (car (entsel "\nSelect the next block (press Enter to finish): ")))
  (if (and block-list (> (length block-list) 1))
    (progn
      (princ "\nDrawing polyline between block pairs...")
      ;; Iterate through the list and draw the polyline
      (setq i 0)
      (while (< i (- (length block-list) 1))
        (draw-pline-between-blocks (nth i block-list) (nth (+ i 1) block-list) offset)
        (setq i (1+ i))
      (princ "\nPolyline drawing complete.")
    (princ "\nYou need to select at least 2 blocks!")
  (princ)
- The 2nd & 3rd polylines were drawn wrong as below photo:
Please refer to the attached files for your information.
Thanks & best regards,
-Kin-
komondormrex
hey,
i think you need to turn off object snapping or put "_non" before every point in (command "_.PLINE" pt1 pt2 pt3 pt4 "").
kinakira2013
Great!
It works as well.
Thank you so much, @komondormrex
