Fillet Command (at the same time)
2 REPLIES 2
alvi_90
240 Views, 2 Replies
Hi guys,
is it possible to connect 10/20 polylines at the same time? the multiple command exists, but every time I have to select polyline. thank youautocad.JPG
2 REPLIES 2
pbejse
in reply to: alvi_90
@alvi_90 wrote:
Hi guys,
(defun c:demo (/ rad r ss i e)
(setq rad (getvar "FILLETRAD"))
(if  (and
       (setq r (getdist (strcat "\nEnter Radius " (rtos rad) ": ")))
       (setq ss (ssget '((0 . "LWPOLYLINE,POLYLINE"))))
  (progn
    (setvar "FILLETRAD" r)
	  (repeat  (setq i (sslength ss))
		    (setq e (ssname ss (setq i (1- i))))
		    (command "_FILLET" "P" e)
  (princ)
HTH
alvi_90
thank you!! fantastic!!
works as I wanted
thank you very much
AutoCAD Inside the Factory
